Question about Bosch Logixx WFR 2466 Front Load Washer
My washing machine keeps stopping mid-cycle & comes up with fault F18??????? Help???????????
    Brigadier General:
  • 6,277 Answers
'F18' for a Bosch is 'pump/drain timeout'
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    DESPERATE..... Displays fault code F18 frequently.Have cleaned the filter 3 times now recently(in the last 3 days) and is very clean but stopped again.Just emptied ll washing out of it and spun it to
    I would check that the drain pipe is also clear.
    You can actually get a build up of old soap powder in the pipework.
    This pipe would be on the rear of the machine (grey in colour) and would connect to your waste pipe (perhaps under a sink)
    If you can pull the machine forward and check to see if this pipe is indeed blocked, or even restricted.
    I found this answer that may help you.
    https://uk.answers.yahoo.com/question/index?qid=20120322120919AANhp8H
    May 12, 2014 | Bosch Classixx WFL 2066 Front Load Washer
    Stop in mid cycle
    washing machine hotpoint hvl211 stops in mid cycle and wouldn't take the conditioner This video will show you how to keep your soap draw clear and how to service the parts
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    And don't forget to like us on facebook
    Aug 03, 2012 | Washing Machines
    Simpson esprit 550 washing machine stops mid-cycle
    Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
    Mar 31, 2010 | Washing Machines
    Washer stop in middle of rinse cycle
    All content © 2000 © 2009 Washerhelp
    > Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
    Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
    Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Our hoover ultra care 1300 large load washing machine spin fault
    The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
    If this is not the case please post back for further assistance.
    Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
    Why is the fault F18 error code on my bosch washing machine flashing?
    Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
    Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
    Bosch Logixx WFR 2466 Front Load Washer Logo
    507 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Craig Butler
    Craig Butler
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
