Question about Car Audio & Video
Why have the speakers stopped working on my stereo. they were working fine until i had to brake sharply then thet all went off together. the stereo is only a month old & is still connected at rear & still seams to be working just no sound apart from a slight buzz from left speakers when i turn it on.
    Sniper:
  • 50 Answers
Hello.. I am sorry to hear you are having a problem. If you have had your speakers changed out recently, it could be that one of the speaker wires or terminals are touching a metal part of the car. What happens is the aftermarket stereo detects this problem and it shuts down all of the outputs to keep from burning up. So all of your speakers going out is a good thing because your stereo protection is working as it should. You can cut all of the speaker wires loose behind the radio and hook them back up one at a time and when the radio cuts off, that will be the bad line. I am assuming of course that you dont have them hooked to an aftermarket amplifier. Even if you have not changed your speakers, it is still a protection circuit that will detect a bad speaker as well. Sudden jolts, braking, etc. can cause a bad speaker to fault. Hope this helped!! Good luck with your venture!
20 year car audio/video installer
Bay manager
Posted on Mar 14, 2011
Testimonial: "thanks for your help. it sounds quite promising. haven't tried it yet as it's too dark but will give it a shot in the morning. "
I have 2007 GMC WITH A 6 SPEAKER STEREO IT ONLY WORKS ON THE FRONT TWEETERS UNTIL I DO SOMETHING LIKE STEP ON THE BRAKE THEN ALL SIX SPEAKERS COME ON PERFECTLY WORKING TILL THEY STOP
Let them try the repair, but I really doubt the technician will pull the door panel, they will likely check the wiring harness from the radio out to the speakers first.
Nov 15, 2016 | GMC Cars & Trucks
The radio in my 2010 Chevy Traverse is acting up, the door speakers on the left side stopped working
There must be a brake in the speaker wires not all the way thou. U need to fallow the wires from stereo threw to speakers n u should find the problom.
Nov 08, 2015 | 2010 Chevrolet Chevrolet Traverse LT
Mighty Max Brake Lights, Stereo & Clock all stopped working at the same time. Any suggestions?
you may have a bad ground, or a short in one of the wires. pull out the stereo.
Aug 19, 2012 | Mitsubishi Mighty Max Cars & Trucks
I installed in my vehicle this head unit and everything seemed to work fine intially. Howevver, when I put the car back together and went back to setup the bluetooth feature for my phone, the entire...
Sounds like it could be a setup issue (software) inside the stereo itself. Maybe try and check out if the manual says any thing about the issue, if not im sure your local stereo installers could help you out.
Mar 01, 2011 | Car Audio & Video
My hx2 was workin fine until one of it went out..but the other seems to work fine still..is it because i hooked up wrong? i replace another one and the same side went out again..
Mine recently started doing this, the reason it is occuring is because there is a short in your amplifier that is drawing too much voltage and sending incorrect feed to your subwoofers. I wouldn't advise you to use your amp until it has been serviced. If you pull out your subwoofer from the box, you should smell the back of your sub, you should smell a crisp burnt smell from the voice coil internally being fried. If you want to learn more about your car stereo system you should check out www.bcae1.com.
Jun 11, 2009 | Rockford Fosgate Punch HX2 RFD1212 Car...
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
I own a 2001 Dodge Stratus RT coupe. The stereo does not work in it. We traced the problem to the amp. We rewired the speakers together bypassing the amp and the stereo worked, but after awhile, the stereo...
Now replace the factory radio with any after market one, run the speaker wires to the location of factory amp and connect wires to all speakers.
Aug 24, 2008 | Car Audio & Video
No Stereo & center sound together in CD mode or TV mode
Something isn't wired correctly, check you wiring and get back to me.
Jul 15, 2008 | Bose Lifestyle 28 System
Speaker issues
Disconnect whatever wire is connected to the blue wire behind your head unit. Re-connect it to the blue/white wire, instead.
Jun 21, 2007 | Sony CDX-M770 CD Player
Car Audio & Video Logo
135 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
