Question about Dell Vostro 1510 Motherboard System Board - J475C
During the starup a black screen appears with white horizontal and vertical lines.....! I know my motherboard has gone bad, can i repair it myself? Thank you.
  • 51 Answers
I wouldn't recommend trying to repair it yourself. I would recommend checking ebay, craiglist or kijiji for another one, usually fixing motherboards is more expensive than actually just buying a new one. Just with a quick search I found this.. http://www.aliexpress.com/store/301244/209554092-318603407/DELL-Vostro-1510-Laptop-Motherboard-J475C-Intel-Video.html
Goodluck :)
Posted on Mar 14, 2011
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
A vertical white line appears on my LG L1520B 15 monitor
This is a horizontal sync circuit gone.
In English, probably cheaper to replace than repair.
Wouldn't hurt to get a quote if it is free.
Jul 29, 2009 | LG L1520B 15" LCD Monitor
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Picture screen
Hello! You have vertical collapse. There are bad solder connections at the vertical output IC. I have repaired MANY panasonic tv's like this. Very easy to repair if you have any soldering experience. If soldering does not fix the problem you need to replace the vertical IC. Good luck
barneyluc
Oct 06, 2008 | Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Oct 14, 2006 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Dell Vostro 1510 Motherboard System Board - J475C Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
