Threading reel to reel
I would also like a diagram on how to thread a reel to reel. Thank you.
  • moonlitsea Aug 03, 2008
    The instructions you provided are very detailed and helpful, although I don't know the names of some of the parts to which you refer. In this case a diagram with labeled parts would be most welcome.
    I saw a question by Barnett009 posted on March 29 to which you replied on 23 April that you could supply a diagram on request. The reel to reel in question was an AKAI GX230D. I don't know how generic the diagram is, but even if it specific only to this model, I would like to see it anyway. Thank you.
    Sergeant:
    Champion:
  • 319 Answers
Depending on which brand of recorder you have, most do have a general threading scheme. As you are facing the unit, the supply (full) reel would be on the your left and the take-up (empty) would be to the right. Position the supply reel so that the leader end of the tape will be on the outside. Pull the tape end around the shut off sensor lever so that it moves freely. Now pull the tape leader between the rubber pinch roller and capstan (in the case the unit has dual capstans). If it has a single roller on the right side, pull the tape between the heads and then between the roller/capstan. If unit has dual shut off sensor levers, pull tape around this sensor as you did the first, making sure it moves freely. Then thread the tape leader into the take-up reel slot. Press play. Both reels should turn counter clockwise.
Posted on Aug 03, 2008
How do I thread the cotton down to wind a bobbin?
have you tried a youtube video that shows the bobbin winding for machines like your?
Dec 08, 2014 | Sewing Machines
Thread is bunching up in bottom.
It sounds like you have no tension on the bottom bobbin reel. Did you check your tension on the bobbin reel. The tension must be right on both sides. When pulling on the cotton when the reel is in its bobbin case you need to feel a little resistance. Adjust the tiny srew on the bobbin case to tighten the reel to avoid it to turn in the casing.
Jan 11, 2014 | Brother PE770 Computerized Sewing Machine
Zigzag stitch tension is too tight but tension is set to zero, any solutions?
This sounds like something is catching the top thread somewhere rather than the tension dial being the problem.
So start by check the threading up path from thread reel to needle, some thread reels have a little cut to hold the thread tail when storing but it could catch the thread during use too. If this is the case, turn reel up the other way or use a mushroom cap over it to assist the thread to flow off smoothly.
Check that thread is going through the take up lever, and not catching on a threading loop, or wrapped around something. It may be caught on something at the back of the machine that you can't see, so just visually check the whole threading path from start to finish, and hopefully this will identify the issue.
Jul 18, 2011 | Simplicity Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
4th cotton reel keeps breaking
check the needle to see if it's damaged or has a burr
check the tension
change thread
check to see if the 4th reel is threaded correctly or if the thread get caught on something
Oct 21, 2010 | Janome Harmony 9102D Mechanical Sewing...
My Husqvarna Designer I has an upper thread tension problem... the thread gets "caught" right at the beginning point of the threading process and the machine comes to a dead stop. There's major bobbin...
My guess is that it is the thread spooling off the reel that is the problem. Some of those specialty quilting cottons come on reels with plastic ends that have rough spots particularly knicks where you are supposed to "park" the thread end when you are done sewing. Run your fingers around the rim at each end of the reel and choose the smoother one to be the one closest to the threading mechanism. If neither end is suitable, flip the spool holder upwards so it is standing at a right angle to the machine, make sure the large spool holder is on then put the thread on - you won't need the smaller spool holder on top. Let the thread feed off from the right-hand side i.e. "under" the thread spool, across to the tension disks etc. Also be sure that the thread is not jumping out of that first thread tension slot.
Apr 26, 2010 | Husqvarna Designer I
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
Threading Diagram
Send me a picture of the front of the deck and I'll mark the picture with the threading pattern, and e-mail it back. ****@rsaaa.com
Jun 12, 2008 | Teac Audio Players & Recorders
Reel to reel tape player akai gx-230D
If you email me, I will send you a diagram
Mar 29, 2008 | Audio Players & Recorders
1,193 people viewed this question
 Grubhead
Grubhead
