Question about Fujitsu fi-5110C ScanMaker Scanner
I was just upgraded to Windows 7 and after using it for about 3 days, now my scanner is not being recognized by the system. How do I reload it to recognize on my computer without any disks?
    Problem Solver:
  • 12 Answers
Http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
kindly update the fujitsu scanner driver for your 5110 scanner to windows 7..
Posted on Mar 23, 2011
How to reload windows 7 on hp pavillion a810n
First, here are Microsoft's recommended minimum system requirements:
http://windows.microsoft.com/en-GB/windows7/products/system-requirements
You will need to have upgraded your memory from the system you had delivered first of all, to either at least 1GB (for 32-bit Win 7) or 2GB (for 64-bit Win 7). In either case, 2GB would be better.
Take your Windows 7 disks (CDs or DVDs) and reinstall it. Possibly you will have an 'upgrade' version of Windows 7. (Your computer was originally shipped with Microsoft Windows XP Home Edition, Microsoft Service Pack 2. If you use your recovery CDs or the Recovery partition on your hard disk, this OS will be the one you get)
25.April.2014
Apr 19, 2014 | Microsoft 7 Computers & Internet
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
I just upgraded from an old dell (windows XP) to a new machine running windows 7. I have an hp scanjet 4570c scanner that I want to use. It ran fine on XP, including the HP director software and the HP...
if you still have the installation disc for the printer use it when adding a printer to the win 7 os
or go to hp download site and download the drivers for the printer
or may be go to the printer properties tab , click on compatibility and tick the box and high light win7 os and apply
Apr 15, 2017 | HP Scanjet 4570 Flatbed Scanner
Cant burn music
1. How old is the unit?
2. Is it connected properly?
3. Is there dust in the cabinet?
4. Is the CD disk compatible with the unit?
5. Have you tried reloading the drivers for this unit?
6. If your software compatible with the Operating system?
7. what Operating system are you using?
8. Did you upgrade to Windows 7?
Sep 17, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Would upgrading from vista to windows 7 speed up the response of my computer ?
yup definitly you will have to upgrade windows 7 one day or another many coll features but going from vista to 7 is no problem at all
reffer to this
upgrade paths
Apr 11, 2010 | Microsoft Computers & Internet
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Fujitsu fi-5110C ScanMaker Scanner Logo
323 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
