Question about GE WBSR3140DW Top Load Washer
My GE washing maching is out of balance and the interior tube leans to the right.. it spend fine with out clothes but once you put clothes in the machine it rocks like crazzy.
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
(Certainly start off by getting the machine balanced and stable) --------->
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 14, 2011
I have a ge profile washer. Can't get it to spin. Even when run thru diagnostics. 70 +- resistance when i check the shifter mode. Is seems like it is out of synch. Starts to agitate as soon as i start...
The pressure switch tube is full of mildew, remove the front panel, locate the clear tube to the left of the tub, remove and clear the tub. Once you clean it blow in the tube to make sure it is clear. You sur here a little click in the control panel. Good luck, here to help. GE authorized
Feb 12, 2014 | GE Washing Machines
The tub of my toploading washing machine leans to the front right, It is balanced and leans whether clothes or in it or not. I can spin clothes if I prop lid open and hold tub straight .
The suspension springs have gone out of alignment or the tub holding mechanism is shifted. look throught the bottom to see the fault in the suspension. correct on the mountings.
Even a leaning can come if the motor suspension is out of alignment.This must be centered in and the top door will close evenly.
Sep 01, 2010 | Kenmore Washing Machines
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Tub free hits side of washer when trying to spin
1- Clothes load is not balance. 2- Tube is balanced by several springs from the bottom tube to the chassis. If one of these springs is broken or slipped out the tube will lean to onside causing this problem. Check these out.
Jan 09, 2010 | Washing Machines
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
My hoover galaxy washing machine stops when clothes are not balanced properly.i have to even out the clothes then start the machine.if the clothes are balanced it finishes its cycle.if not the machine...
Hi
It is normal for the drum to sway excessively and hit the balance switch if the load is not evenly distributed around the drum or if you have excess cloths.
Once the balance switch is trigerred, you can reset by openning and closing the door. It is a safety mechanism which stops the spin cycle if the drum sways excessively.
If this tends to happen often, then you need to make sure the machine is properly balanced and not leaning too much to the back.
Also the drum suspension rods do tend to wear out over time and loose their firmness, causing the drum to sway excessively. You can check this by opening the lid. Pushing down and from side to side onto the agitator, and seeing if their is a firm bound on the drum. Also making sure the drum returns to centre position. If the suspension springs feel loose and wayward, then they will need replacement.
Regards
Ash
Nov 08, 2009 | Washing Machines
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
Twisted washing - double sheet in 5.5kg top load
its a bit of both. You need to lay the sheet around the tub rather than tossing it in. You also need to ensurehe right level of water for the volume of clothes and the clothes should be submerged
Aug 14, 2009 | Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE WBSR3140DW Top Load Washer Logo
50 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
