Question about Microwave Ovens
The turn table does not move - Microwave Ovens
  • Microwave Ovens Master
  • 6,771 Answers
Unfortunately the motor is defective and will need to be replaced in order to get it back to working standards.
Posted on Mar 14, 2011
  • John Cunningham Mar 14, 2011
    Sorry! forgot to mention it is the turntable motor that is the culprit.
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
How do I fix a Microwave?
A microwave is not a good candidate for novice repair. However, since it isn't completely dead, the power circuit is likely intact (not a blown fuse). The major components involved are the capacitor and the magnitron. The cheapest is the capacitor. If you have to replace the magnitron, it is not likely economically feasable. Be careful of the cap - it contains energy even when unplugged!
Jan 02, 2015 | Kenmore 30" Microwave Combination...
Why
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
Thermador opion 3 micrawave does not work
First if it has a turntable and everything lights up etc, does the table move or not? If it does but no heat/cook possible inverter board or even the Magnetron unit.
If table does not turn it may be a safety switch located in the unit that is not engaged (have to get at from inside unit).
Nov 04, 2012 | Thermador MBBS Microwave Oven
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
My daughter just moved into a townhouse and the microwave plate warms, however the plate doesn't rotate. Is there any easy way of fixing this issue
The rotating table in a microwave shouldn't be getting warm unless something is sitting on it and transferring heat to it. The chamber should not be left empty when the microwave is running. The motor that drives the table is of very low mechanical power but should be able to handle about any load it must. I suggest you remove the glass table, the ring on which it rides, put a cup of water in the chamber and turn it on. Look at the drive spindle that engages with the table when installed. If it isn't rotating 9should be easy to see) then the motor is defective which is highly unusual to see one fail. If the spindle is clearly not moving, then I recommend replacing the whole unit since while the part isn't expensive, the labor cost would likely make the repair uneconomical.
Dec 22, 2010 | GE Microwave Ovens
Microwave Drum not moving Problem
Remove the plug and take the turn table out of the microwave cabin. Now keep the microwave rested on the side andopen the back pannel,you can see the turn table belt drive.If this is broken replace.if not trace the motor connection and mark them.Now heat the microwave in normal position,place the turn table and a cup of water.Close the door and switch on the microwave set for a minute.Now check the voltage on the motor line marked.If present ,then the motor is fault.If not the controller board is faulty, and must be traced.Can be the relay drive or the relay. hope the other sections are working fine.
Aug 31, 2010 | Microwave Ovens
Turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get to.it does sound as though your motor has gone bad.
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
