Question about Dell Computers & Internet
On a dellmodel pp39l when the power is turned on it beeps 2 times and doesnt start up
    Scholar:
  • 80 Answers
I could not find any beep codes that show only 2 beeps, please refer to the Dell Support website to find out what beep code best matches what your laptop is doing
http://support.ap.dell.com/support/edocs/systems/pe650/en/sm/beep.htm
Have you recently taking apart your laptop? If so then double check to make sure the RAM is seated correctly, remove the battery plug in only power and try turning on the laptop.
Please rate if this helps,
Posted on Mar 14, 2011
When i press power it doesnt turn on, instead it beeps 2 times then no power at all.. then when i get through it after the acer apprears the window icon will show then it start beeping about 15 to 20...
this sounds like dodgy RAM, open up the back covers on your laptop until you find the RAM once you have done this reseat the RAM in the opposite slot and try again.
if it still doesn't work try with individual sticks. if it works perfectly with one but buggy with the other then it is the RAM.
Dec 20, 2013 | Acer TravelMate 5520 Notebook
Pp39l
IF THE COMPUTER STARTS AND YOU GET NO PICTURE,AND BEEPS YOU GOT MOST LIKELY MEMORYPROBLEM.
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HERE IS SOMETHING READ ABOUT BEEPING CODES AND UNDERSTAND.
Jun 18, 2013 | Computers & Internet
The PS3 starts with the logo and the "waves" and
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps.
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 turns on but the av multi out doesnt work so i cant see or hear anything.
Try resetting the display by doing the following:
Step 1. Turn the PS3 off into standby (red light on)
Step 2 Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3 Wait for your PS3 to start
Hope this helps
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Got a playstation 3 ,you turn it on and doesnt load to the main screen only comes up with ps3 and then the wavy lines can u help
Ok, follow these steps to fix your PS3, unfortunately you will lose your save game data!!
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, beep 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will load. Select option 5 "Restore PS3 system". The console will ask you if you are sure, just accept and then the PS3 will restart. All the original software will be loaded and you will need to enter the date and time and other details.
When you have done all this your PS3 should be fully working again.
Hope this helps and thank you for using FixYa
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
Computer doesnt start FOXCONN 865A01-PE-6EKRS
Most of the times beeping at the start up refers at problems with the memory. So try starting your computer with 1 memory stick at a time, placed at the slot near the CPU (usually marked as DIMM 1) to find out memory error.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Foxconn 865A01-PE-6EKRS Motherboard
Doesnt turn on and beeps, philips match line rear
i believe it takes a couple minutes for the pamp 2 warm up and the start
Aug 22, 2009 | Televison & Video
Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Apr 20, 2009 | Computers & Internet
Starting problem
check the processor fan is working or not. check its connector. Also check if there is any beep sound.
if processor fan is ok then disconnect all the cables, data and poewer cables. plug the power connector to motherboad only and listen if there is any beep sound there.
tell me after doing this, if problem doesnt solve.
regards,
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
789 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
