Question about Elation Stage Setter 8 Dmx Controller
StageSetter 8: when the power switch is turned on the internal fuse blows immediately.
  • Elation Master
  • 5,603 Answers
Likely the filter caps or the rectifier diodes have shorted. Power supplies are easy to work on unless the are switching type.
To work on this, replace the fuse and put a 25 watt light bulb in series with the hot side of the inout power... saves fuses and will send enough current in to troubleshoot with a meter. Use SAFE procedures when working on electrical equipment. For switching power supplies you need to use a line isolation transformer for personal safety.
Posted on Mar 14, 2011
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
Why my Marshall amplifier immediately blows fuses?
It could be a failed power supply capacitor, it could be a shorted speaker, it could be a shorted cable. It might also be a conductive piece of trash in just the wrong spot on the circuit. They would be the big ones of about 5000 microfarad give or take a few hundred microfarads.
Though a little less likely, there could be a short of failed component in the output stage.of the amp.
Sep 25, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
The fuse blew, can't read what the ampage is
This doesn't compute as there is no fuse external to the unit and it runs off a 12 volt wall wart supply. The supply is 500ma or more. Any INTERNAL fuse would probably be rated at that or slightly higher like 650 ma or even 3/4 amp. If the internal fuse blew it was for a reason... using wrong adapter probably would do it... Other than that take it to a competent repair shop as the fuse will probably blow instantly again. This appears to take 12 to 20 volt 500 ma minimum wall adapter with CENTER positive, unlike many devices. If you put wrong polarity adapter that would probably blow the fuse and MAYBE another component.
Apr 26, 2011 | Elation Stage Setter 8 Dmx Controller
What fuse does the Presonus ACP88 use? and why does it blow?
Do NOT replace fuse without repairing the CAUSE of it blowing. Fuses blow as a result of excess current being drawn. They protect from further internal damage. They can blow because of an internal failure or because the inout power is outside of the specified value...ALWAYS check your power source. Always power all interconnected equippment from one receptacle or power source.
Jan 18, 2011 | PreSonus Acp88 8 Channel Compressor...
I want to know where i can get a new fuse for my pmp 5000b-212XL powered mixer ?? and waht kind of fuse is it ?
If the fuse has blown DO NOT replace it without repairing the cause of the failure. You will likely do more damage to internal components. Take the unit for repair before applying power again. I have repaired many of these and first a failure occurs in one of the power amps... usually the A channel, then people replace a fuse that protected the power supply and that blows the power supply taking out another $30 of components and $200 labor. (they are hard to change) If the unit is under warranty, exercise your warranty immediately. There is a weak spot in the channel A power amp.
ALSO please read my tip on here about a hazard in PMP series powered mixers. It is in regard to using Speakon to 1/4 inch speaker cables... NOTE that the BARREL of a 1/4 inch speaker cable or adapter from the Speakon is the HOT side for channel A and if you ground it inadvertenly, goodbye channel A power amp!!!
Jan 04, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
Marshall mg100dfx, internal fuse blowing every time you switch on the unit. What could be the problem
The way you troubleshoot this is to put a 150 watt lamp in series with the input power cord. The lamp acts as a resetable fuse and will limit the current while you look for the bad component. Start with the capacitors and rectifiers connected to the power transformer.
Sep 30, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Where can I buy a fuse and fuse holder for my Behringer pmp 3000 power mixer - can anyone tell me pleas Lyn
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hi im in Argentina and i accidentally pluged in my amp without an adapter now it doesnt work what needs to be fixd?
The power supply is blown. Argentina is 220V I believe. I have never seen a power supply schematic for this however being that it is low power it is a linear supply not switching. Either the rectifier diodes are blown out or possibly the output capacitors are blow due to approx double voltage. If you try this yourself be careful otherwise get a new amp. Good Luck
Dec 14, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
Elation Stage Setter 8 Dmx Controller Logo
302 people viewed this question
Top Elation Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Elation Music Expert? Answer questions, earn points and help others
