Question about Craftsman Saws
Does the bolt turn R or L also does it take a special tool. I have had this saw for 28 years and my guys changed the blades I fear they lost the tool. Also will a 10" blde work it has a 71/4 now
    Sergeant:
  • 462 Answers
If its a 10 inch saw it will take a 10 a 7.25 wont
Posted on Apr 21, 2014
    Problem Solver:
  • 6 Answers
The bolt on your saw blade turns right. Hold a block of wood against the blade so the bolt can turn. You can use a adjustable wrench if it will fit. Otherwise see if an open end wrench will fit. The 10" blade will only work if the saw was designed for a 10" blade and there is enough clearance.
Posted on Mar 15, 2011
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
How to change the blade on a skill compound saw
Take the bolt off and change blade, put bolt back on.
Oct 18, 2014 | Saws
I lost the blade change wrench for fire storm 10 inch table saw,cant find a tool that will fit
probabbly have to order off line. or sears hardware may carry them. or a speciality woodworker store.
Jul 08, 2011 | Black & Decker 10-in Firestorm Table Saw...
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Mar 16, 2011 | Wet International Q.E.P 4 inch Portable...
How to change a blade in miter saw
There is a button on the saw near the axis the blade spins on push the botton there should be an allen wrench that is supplyed with the saw that is mounted or stuck or attached to the saw this fits the bolt that secures the blade the bolt that holds the blade turns left handed so most bolts turn righty tighty lefty lossey this is oppisite turn it clockwise to lossen it
Dec 03, 2010 | Makita LS1013FL 10" Slide/Compound Miter...
7 1/4 B&D saw - blade stalls but motor continues to run
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Jul 28, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How to get blade off
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the right side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For a worm drive saw with the blade to the left of the motor, the bolt should have left hand threads (non-standard) which means you loosen the bolt by turning it clock-wise.
Oct 02, 2009 | Skil HD5825 6-1/2" Worm Drive saw
I have a ms 150 miter saw that a relative gave me. Blade needs to be changed but the locking mechanism is stripped. How can I remove the bolt that holds the blade in place. Also the blade turns clockwise...
Jam a piece of wood between the blade and the table to stop it from turning while loosening the bolt. Circular saws never had locking mechanisms until recent years.
Mar 15, 2009 | Saws
Need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
Mar 11, 2009 | Hand Tools
Saws Logo
96 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
