Question about Bosch Brute Breaker Hammer 11304
I have a bosch brute hammer drill, that just stopped working after 2 hours of breaking up concrete and rock. It is brand new, and worked fine to start with, but then gradually took longer and longer to start going. ' Now, it won't work at all. Any ideas?
  • Anonymous Mar 20, 2014
    my sds drill stopped hammering when i was breaking out some concrete and will no longer work on any function but still turns on when you press the trigger. i have replaced the bushes but its still the same. any ideas?
    Thanks
  • 35 Answers
Take it back as it is still under warranty. If there was anything you could do other than letting it cool down it would be in the instructions.( which you have since it is brand new.)
Posted on Mar 15, 2011
    President:
  • Bosch Master
  • 1,388 Answers
Bosch brute is made to work all day every day and will continue to do so if it is not over or under powered. If not powered correctly, motor will get very hot and burn brushes to point that auto stop feature will stop motor (brush will push away from armature, or burn switch). The hammer will overheat if too long or wrong gauge of cord is used. Also if run on generator with voltage /cycles incorrect. Under normal use, motor will not get very hot. Another problem with overheating is that the grease will melt out of range to do any proper lubrication. Chect switch first, then brushes. If brushes wore down to auto stop, check for damage to armature or field windings. If armature or windings were overheated and damaged, the motor will not turn up to proper speed and new brushes will burn very quickly. Good luck
Posted on Mar 14, 2011
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Oct 11, 2009 | Bosch Drills
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Bosch 1199vsr stopped working while drilling through concrete. The reverse works. Help
your tool should have a rotating reversing switch and the contacts for the forward rotation might be dirty or burnt. I would unplug the tool and remove the screw holding the back handle half on and look to see if anything is burnt or just dirty or bent. If you have an air compressor try blowing thru all areas of the tool. Let me know if this doesn't work you can also go to Boschtools.com and type in your model number on the left hand side after clicking on manuals.
Jun 28, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Bosch Brute Breaker Hammer 11304 Logo
883 people viewed this question
Top Bosch Hammering Experts
John Trevino
Mike
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
