True frezer is loosing charge in 3 days cant hear leak with nitrogen and has dye in it but looses charge in 3 days what is the best way to find the leak
    President:
  • 1,515 Answers
Hi, be sure you are putting enough pressure with the nitrogen tank and get your self a bottle of gas leak detector at any hardware store, soap up all the fittings you can get to. About 200 p.s.i. of pressure will force the leak. When a unit leaks, it will leak at the weakest link on a system, so the weakest is the valve stems where you charge it. If you have added a dye solution, do you have the blue light that comes with the dye kit to find the leak? I will bet if you are loosing freon at that rate, you have a leak in the evaporator coil. I leak check units every day, and if you have soaped down all of the lines, fittings and so on, 95% of leaks I find are in the evap. coil. Check the cap tube, as a lot of times I have found leaks from them rubbing against any metal parts and rubbing a hole in the line due to vibration from the compressor. If you are using dye, you need the U.V. lamp to scan all parts to find the leak, you can't see the dye with your eyes, only when its dark and with the uv, ultra violet light to see it. It will show up a yellow color. Pay good attention to where the liquid line feeds the evaporator coil and the capillary tube are insulated. You may have to peel it off, sometimes I have found the leak under the insulation. A box that size does not hold a lot of freon, so get to the evaporator coil, use the U.V. light, and get the soap, it works wonders for leak detection. Please let me know. I will wait to hear back from you. Good Luck, you will find it!!
Shastalaker7
A/C, Heating, & Commercial Refrigeration Contractor
PS, when using the U.V. lamp, get a tarp to put over you to keep it as dark as you can. Scan areas at least 2 to 3 times.
Posted on Mar 14, 2011
Have a 97 XR7 cougar 4.6L The AC blows warm. A has been charged but only lasts for a couple of days. Dye was sent into the line but no leak was found in the engine bay What can I do to repair it.
Make sure the heater tap is shutting off correctly, this will cause heat no matter how cold the a/c gets, you can test by clamping off the inlet heater hose with a rag and pair of vise grips, be carefull not to damage the hose.
Also if it is loosing the charge of refrigerant gas, it will need to be pressure tested with nitrogen.
Common places for leaks are arond the fittings and hoses to the compressor, because the suffer the most movement and wear, Also inspect the seal on the compressor.
Feb 26, 2018 | AC Cars & Trucks
Oil leak
oil can leak in several places n your car,valve cover gaskets ,oil pan, rear main seal timing covers, oil pressure switch, oil drain plug, adn the oil filter if on too loose or if punctured. go to your local parts house and pick up a small ultra violet flashlight and 1 bottle of oil dye.( this will not harm your oil or the engine so you could leave it in until you change oil again) Install the dye in the oil filler cap and replace the cap. Next wipe away all the oil you can get to from the top and bottom of the engine. drive vehicle around the block 3 or 4 times allowing the dye to circulate and leak out. Now take your black light flashlight and start looking for a bright yellow or green to show up on the engine. Follow the green line right back to where it came from, there is at least one of your many possible leaks.
Apr 18, 2013 | 1998 Dodge Caravan
2002 dodge intrepid keeps loosing freon cannot locate leak
probably the evaporator core under the dash leaking
Jul 10, 2012 | 2002 Dodge Intrepid
Cant find refrigerent leak on 04 trailblazer
Mechanics use dye or a device that "sniffs" for leaks since the gas is hard to see.
Putting in fluorescent dye allows you to see the dye with a black light.
The sniffer picks up a component of the gas.
If the system was charged before you replaced the compressor, the leak should be at one of the gaskets you replaced, or you have a defective compressor which is leaking at the pulley seal.
Jul 01, 2012 | Chevrolet TrailBlazer Cars & Trucks
1997 plymouth air conditioner cools when charged,,but looses charge
CHRYSLER PRODUCTS ARE KNOWN FOR HAVING LEAKY EVAPORATOR CORES. BUT THE BEST WAY TO CHECK IS TO PUT DYE IN THE SYSTEM AND RUN THE SYSTEM TO CHECK FOR LEAKS. ALSO A GOOD A/C TECH WILL HAVE A REFRIGERANT SNIFFER FOR SMALL LEAKS. ALL IN ALL IF ITS NOT FOUND IN THE ENGINE COMPARTMENT ITS PROBABLY THE EVAPORATOR.
Aug 01, 2010 | 1997 Plymouth Voyager
I have a coleman evcon suncutter unit that is just for a/c. It works fine except it does not blow cold. I've had the repairmen out here to look at it and they have looked for leaks. Their recommendiation...
Hi, the problem you are up against is where the leak or leaks are in the system. If the leak is in a coil, the evaporator or the condenser coil, it would be cheaper to replace the unit then to install a new coil as it is impossible to repair an aluminum coil with a torch and silver solder. And you cant put a liquid patch as epoxy will not hold due to the pressures in the system. Now, what the service techs should have done if you have a leak in the system, is charge in a dye pack which will go through the system and find out where the leak is. Then they return and with a ultra violet light, they scan the unit to locate the leak. I have repaired so many leaks that I have been told I would never find and proved them wrong. Did they even try and locate the leak? The E.P.A. requires by law that the system must be leak checked upon a call or make every effort to find the leak, this is the law. I see now that they have looked for leaks most likely with a sniffer or soap bubbles and cant find it. This is when you pull out the dye kit, I can find 99.9% of all leaks with using die. In my field of refrigeration, air conditioning, and heating, I would be lost without a dye kit. Yes, if a coil isn't rotted out, it can be fixed. They can also pressurize the system with dry nitrogen and do a leak check this way. It just sounds like to me they don't want to mess with it. I would call them out and have them do the dye check if you want to try and save it.Please keep me posted on this.
Best of luck,
Shastalaker7
Mar 20, 2010 | Coleman Heating & Cooling
LG A/C SPLIT UNIT, DURING DAYS WE WERE SMELLING GAS THEN SUDDENDLY ITS NOT COOLING ANYMORE, SO WE THINK THERES A LEAK, HOW TO FIND IT AND FIX IT?
you will need a pair of guages and some nitrogen. put pressure to the lines and listen for the "hiss".rubbing soapy water on the area where you think the leak is at will make bubbles (the leak). another way is dye but i do not reccomend it. once you find the leak you run into the problem of soldering the leak and recharging the system, which requires an epa license for the purchase of refrigerant. yout best best is to call the pro's. this is tedious work.
Oct 08, 2009 | LG Heating & Cooling
BMW 320i is using 5L of oil every 1000miles no
Try using an automotive dye in the oil the oil has to be going somewhere the dye should reveal the loose gasket or loose oil plug in which the leak may only occur at speed under pressure and not present when stopped
Aug 20, 2009 | 2002 BMW 3 Series
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
