Question about Acer Aspire One PC Notebook
I have at&t phone service can i hook up my notebook through using my phone line. I don't have hook up anyother way in the house.
  • 2,632 Answers
Welcome to Fixya. If you want to connect the notebook to the internet you need to have a service form at&t either Uverse or DSL becuase you need to have a modem or a router to convert the phone signal to data signal to have an internet connection.
Thanks.
Posted on Mar 14, 2011
Phone is showing line in use when it is not and there is no phone off the hook
if there is no dial tone , check phone connections in the house
could be an external line problem so report it as a fault to the service provider
they can test the line to the house and tell you if it is your phone tat is at fault
Aug 18, 2016 | Lands Phones
How do i connect phone to laptop connection
So do you have internet service at the house? If so you can plug the ethernet cable from the modem directly into the computer's ethernet port.
If you're talking about directly connecting to your cell phone, then the phone has to have the built in router in it. If it does, you can connect your computer to it wirelessly.
If you're talking about a regular old house phone (land line) then you would be very slow if you could get it connected. I don't think the newer models of computers even have a modem port to connect a telephone line into it. But basically you would still need a internet service provider to connect it.
Bear in mind that there is a difference between the phone cord and the ethernet cord. The phone cord is smaller in size and the end that plugs in is smaller.
Apr 03, 2012 | Computers & Internet
I have a dial tone coming out of the jack on the wall that is only for this fax machine but the fax machine is saying phone off hook.
,Line should be connected to directly to printer line in port, parelall phone should be connected to extention port,don't split the line for printer & phone. Telephone line voltage should be 48V with/without line connected to the printer, if any voltage differce replace LIU card..
Sep 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I get busy tone when calling my home phone. All phones are on the hook.
If you know where your phone box is where the lines enter your house you can take the cover off and see if there is a wire loose or broken.I don't know how your service provider is but several of them have seal on the boxes and get upset if you try to repair it yourself so you might want to have them send someone out to check. With most phone companies that I have worked with if it is on their side they will fix it for free but if it is on the incoming line then they will charge you. Hope this helps you some. Thank you.
Jul 10, 2011 | Home
I have n 95 china phone i need to use internet connection
You can go on internet via your service provider or if you have an ADSL modem,you can use the WiFi facility on the phone.If you don`t have ADSL,speak to your local land line provider for an ADSL subscription.Nice and handy to have a system like that.You can go on the internet from anywhere in your house or bed,day or night and it costs you only land line subscription.
Mar 17, 2011 | Nokia N95 Cellular Phone
Hi I have a laptop of Dell & i have a phone of Samsung Mode GT-C3053 Handset GPRS Compatible I want to connect my phone to laptop for using internet Can you have any solution
Are you hooked up to the net through your phone company? If so, all you need to do is plug a phone cord into the right place on the PC, & be sure to hook up a filter they sent you from the company, if there will be phones hooked up to the same line. If you have a line dedicated ONLY for internet use, just plug in the cord, run the disk they sent you, & you're set. Do you have dialup or broadband? That also makes a difference. Dialup you can do the above & add a phone running from PC also, np. BUT if you have broadband & you want to have a phone & PC hooked up to same line, you want the phone to come off a line BEFORE it gets to the PC, as the filter thing is important. Put filter on the phone line. If you have broadband & a phone that runs off line from PC, you will hear horrible sounds louder than voices on the phone. Ask my ears, I tried that. :) If all that doesn't help, ask again & tell us lots more about it, OK? :) More info helps a lot.
Sep 18, 2010 | Samsung Computers & Internet
I have aquired a toshiba dkt2010-s digital business phone, and when i hook it up to the line at my house all i hear is clicking, what am i doing wrong?
phone line is not on. call service provider and have them cut the line on....they will only cut on the line you are using, and not ALL the jacks in the house!!! ...call and tell them you want this one cut on, someone may have to come out, but may be able to do it over the phone! Good luck
Jun 12, 2010 | Lands Phones
Setting up fax feature
get a separate telephone cable and attach it to your fax, switch line over from phone to fax manually at the phone line input on the wall, it's the ONLY way I can manage that same problem. If you forget to "switch" your lines over, unplug the fax from the wall & answer your other house phone that's plugged into the wall. Works every time. It takes a little effort, but why pay for more phone lines when all you have to do is plug/unplug an extra phone line?
May 16, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
CAN'T GET FAX WORKING.
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
Will not fax
Hook a phone to the fax line and try to dial out... a fax line is no different than a phone line at your house ,, don't use a multi line phone like the ones at the office use a phone like you would have at the house to hook the the fax line .. If you are able to dial out call someone and check the line for static and pops they can cause the fax not to work either.. Good Luck
Mar 31, 2008 | Ricoh 2050L Laser Fax
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
