Question about Grundig YB 400PE AM/FM/SW Radio
Radio works with the adaptor but when you take the adaptor out and it's just on batteries the radio does not work. Yes, we have replaced the batteries
Will not charge
Check your power supply. If the all the charging cups are not working you might have a bad power adapter.
Feb 07, 2014 | Motorola Cls Multi-unit Battery Charger...
Hitachi UR18DSL site radio. works when plugged in, but not when fully charged battery inserted
test the battery with multimer for to see is o.k with the voltage. measure. Otherwise you can put the package with plastic bag(windzip) and put by 24 hours in the freezer from your refrigerator for to revival of your battery. and try again in your radio. ( this is smal secret for revival battery rechargeable.
God bless you
Nov 07, 2013 | Tivo DirectTV Remote Remote Control
My samsung n150 mini, was working very well.suddenly, the screen turns into black and no sound of the processor. Screen and battery flashlight indicates that they dont work.what is happening?
Does the laptop start up with power adaptor plugged in?
If yes then battery may be dead, you can check for a replacement online, battery model may be AA-PB2VC6B but check the battery label to ensure you note the correct battery model.
If the laptop does not boot with the power adaptor inserted, remove the battery and try booting with just power supply inserted and see if laptop boots.
If still not booting then it is a hardware fault, either battery, power adaptor or internal part possibly motherboard, you will have to contact Samsung for repair.
Good Luck
Jan 10, 2013 | Computers & Internet
I have had a Sony ICF SW7600 for the last 18 years. Now, it only wishes to work on batteries and not on the AC adapter anymore. What can be the problem and how to fix it
I have the exact same problem here in Europe with my perfectly with my Sony shortwave after 18 years. If I fiddle with the ac adaptor in the radio plug, it works for a while. I have replaced and soldered the yellow tip adaptor twice in 18 years and hopefully the problem is with the power plug and not the radio plug.
Any help is appreciated.
Dec 20, 2012 | Sony ICF-SW7600 AM/FM/SW Radio
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
Will this radio work in a 2005 Ford Focus hatchback
Yes but you will need a Quadlock to ISO harness adaptor and antenna adaptor and facia adaptor, roughly £30 of parts.
Nov 20, 2009 | Pioneer DEH-P5800MP CD Player
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Nov 01, 2007 | Audio Players & Recorders
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Grundig YB 400PE AM/FM/SW Radio Logo
43 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
