Question about 3Com OfficeConnect Wireless Router
I have forgotten my password for the router and it doesn't reset. I've tried admin, password and adminttd but none of them works
    Novelist:
  • 100 Answers
Not quite clear as to your problem. Are you trying to access the web-based configuration page for the router (for which you need an administrator password)? Or are you trying to make a wireless connection to the Internet via the router (for which you need the wireless security key)?
Those are two separate passwords, and you may be able to retrieve them both. The administrator password would be stored in the computer that was used to configure the router. The security key should be in the computer which configured the router, as well as any computer which made a wireless connection to the router.
You may find it helpful to check the owner's manual. (If you don't have that, you may be able to find a copy online and download - be sure to search for the correct model.)
If you can access the web-based configuration page for your router, you should be able to view (or reset) the wireless security key. (Check the owner's manual for your model.)
If you're not able access the router's configuration page, and the passwords are stored, you should still be able to retrieve them by installing some free software.
For the computer that configured the router, download and install this program:
RouterPassView by NirSoft
http://www.nirsoft.net/utils/router_password_recovery.html
http://www.softpedia.com/get/Network-Tools/Misc-Networking-Tools/RouterPassView.shtml
For a laptop that connected to the router, download and install this program:
WirelessKeyView
by NirSoft
http://www.nirsoft.net/utils/wireless_key.html
http://www.softpedia.com/get/Security/Decrypting-Decoding/WirelessKeyView.shtml
Posted on Mar 19, 2011
When i put in default username and password says its not authorized
Try admin in user anme and admin in password.
If that doesn't work then try admin in only password, leave the user name blank.
If that doesn't work then try some different passwords that you use often.
If nothing is working then you will need to reset the router.
Once you reset the router, you will lose all the settings on the router and you will need to reconfigure it.
See How to setup Linksys router
Apr 23, 2012 | Cisco Linksys EtherFast Cable/DSL Router...
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
How to know wifi password
The wifi password is set internal to the router by the router's administrator. If that was you, then you are saying you've forgotten the password. If that is NOT you, you are asking for the password. You must get that from the administrator of the router. If you have a used router, it may have been previously setup by another admin and you are trying to access it. If the previous administrator left the unit in its default state, it can be accessed at IP 192.168.0.1. The default user name is to be left blank, and the default password is admin (lower case). If that doesn't work, you ay have no choice but to reset the router to get it back to defaults so you can gain access to it. There will be a reset switch somewhere on the unit (usually accessible thru a small opening) that you must press and hold for a period of time. Be warned that this will erase all custom setting in the router and will require a new setup, but will allow you to regain access using the default user name and password.
Dec 17, 2011 | D-Link Tmobile Hotspot Tmg5240 Wireless...
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
How can i reset the password to my wireless router (wr850G) I've held down the reset button for more then 30 sec on and off with no luck and when I try to log into the router through a wired connection...
Did you try unplugging it, holding the reset button for 30 seconds, then plugging it in (while holding the reset button), then (after I'd say like 5-10 seconds) letting go of the reset button? Also, if you're seeing a blank configuration page, it could be that the username/password combination is wrong. Try using username "admin" and password "password" "1234" "0000" "admin" and leaving the password blank. One of those combinations should work.
If none of those work, unfortunately, it might be that somehow the router got damaged or broken somehow. You can try some of the steps from the manual (located here) to get it to work again, but you might want to look into a new router.
Jun 16, 2011 | Arris WR850G Router (DHWR850G)
Need security key for linksys router
If it is your router your trying to access try these https (only necessary to try second one if first doesn't work)
these are the network/password config for linksys
http://192.168.1.1
http://192.168.0.1
May 06, 2011 | Linksys WRT54G2 Wireless Router
Hi, Forgot my 3com 5012 router password. Can you please assist me?thanks.
Please try with the below combination of passwords for 3com Router
synnet
tech
(none)
admin
ILMI
PASSWORD
adminttd
comcomcom
security
Jan 21, 2011 | 3Com Router 5012 (3C13701US)
I have forgotten username and passsword on my router
The common username and password are the following:
Username :admin
Password :admin
Username :admin
Password :password
If these does not work try to reset the router to factory default and then the same would work
In order to reset either there would be a dedicated reset button either on front or back of the router,or there would be a reset hole where u need to put in a pin and hold it for 20-30 seconds, if none of them are available press the power button and keep it pressed for 40 - 50 seconds, it should work
Jun 14, 2010 | Computers & Internet
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
Password retrieval
There?s not much you can do. Try to put the router?s default password which is ?admin? (lower case) and then copy the settings so you can reconstruct them after the reset of the router. Hope it works good luck.
Feb 22, 2006 | Linksys Wireless-G Access Point WAP54G...
3Com OfficeConnect Wireless Router Logo
103 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
