Question about Sony Playstation 3 (PS3) Console
Wont read the hard disk,
I've tried everything and i can't get my PS3 to work, doesn't go to the home screen just says cannot read hard disk, would rather save 150 dollars because i can't find the reciept. Already tried taking the disk out and putting back in, restarting the console and leaving it alone for a while. Still won't work, please help.
    Problem Solver:
  • 35 Answers
PS3 is The amazing device by sony but it has some common problems like disc read error . Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 12, 2009
  • 344 Answers
Hello baddestsob,
Most likely you need a new hard drive. Just take out the one you have and get the same exact one or even one with more GB. You can get them on eBay for about $20-50 (US). Just be very careful not to mess up the screws that hold the hard drive onto the holder. This should save you some money.
OR
If your PS3 is still in warranty then call Sony.
I hope this helps. Good luck!!
Posted on Aug 01, 2008
PS3 slim doesn't read disks
Was the system "cracked" or "jailbroken"? If it was, then the system would have "bricked" (stopped working) and you'd be lucky if you got it to turn back on at all. Now it sounds like the same problem my slim had. Everything works fine in the system, except reading the disk. Unless it is under worranty, it is going to cost you for an out of warrenty repair. Exactly $105.00. BUT, there is good news in this, when they replaced and repaired mine, everything in it was brand new. So I basicaly had a new system. Well worth it.
Apr 05, 2013 | Sony Playstation 3 (PS3) Console
I'm installing a biostar a78ldm2s and everything turns on but I keep getting a read disk error on the hard drives that I try to use. I've tried 5 different hard drives and get the same result.
Hello here you can download a manual:
http://www.biostar-usa.com/app/en-us/support/download.php
By entering the right mainboard number.
Try to set the bios to factory settings.Load default settings.
And set the boot order: first boot device:dvd, second, the harddrive.
If you are using a IDE drive make sure its set as master.
A sata drive does not have that function.
Make sure the windows disk is clean and without scratces.
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=sMc5ukMguEo
Good luck
Nov 04, 2012 | Biostar A780L Motherboard w/ AMD Athlon X2...
My hp pavilion dv7-4285dx has lost everything, os and all. How can I get it to read the recovery disc I ordered from HP?
What makes you think you've lost everything? Unless you specifically instructed your computer to Format the hard drive, I would doubt very seriously that you have lost everything. Everything might still be there, but a virus has hidden it to make you think you've lost everything. Oh, one more way to lose everything is to interrupt a System Recovery before it completes, or interrupt an Fresh Install of Windows before it completes.
A lot of times the System will think you've lost everything because somehow a setting the bios was changed either by you or some virus and it has set the hard drive where it is not detectable. Turn your computer off then watch the screen to see which key you have to hit to get into the BIOS or SETUP or System Setup.
Once you are in the BIOS scroll through it looking for AHCI that will be associated with disk drives or disk controllers. If it is Enabled, Disable it and Boot your machine. If it is Disabled, Enable it and Boot your machine. In other words just change the settings for AHCI.
Do that and report back.
Mar 22, 2012 | Computers & Internet
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will not play no games or dvds
If you have warranty with your PS3 you can send it to Sony so they can fix it. If you don't have warranty anymore then they will charge you $150 (that's a 150 dollars or some people said it was more pending on the different problems) for the repair of your PS3. Either way it can take up to 6 weeks before they send your PS3 back. Also note they wipe your hard drive contents!
Speaking of which you might try just this: reformatting your PS3 hard drive!
But if that doesn't work and you're not ready to pay that amount I suggest you use a guide that let's you repair your PS3 by yourself without the need of opening it. Such a guide fixes stuff like Yellow/Red/Green Light of Death (is your PS3 having one of those lights?) as they call it and other common problems with PS3 consoles (error codes, black screen, disk errors, error codes). Click here to read about this do it yourself guide.
May 16, 2011 | Sony Playstation 3 (PS3) Console
My ps3 wont show an image on to a tv.
try to reset your ps3. hold the power button and it will beep a couple of times do this three times. it will reset your system and work as long as you have no other issues
Jun 06, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont read disk actually no disk shows up on the screen just the memory hardrive and the demo's right below were the disk should show up, but no disk option
there is two wires in the ps2 that might not be connected did you get it from eBay or something? if not just return it in to Sony , or its because you have a bad blue ray drive
Jul 10, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont read disks
This is a laser problem. Blu-ray drives use a laser with a magnifying lens, and any dust on them at all will cause problems. These lasers are also known to fail and cost around $50 for a new one on ebay. You can also do a fan test to blow out your system. this works much better than using an air compressor. To do this, turn off the power switch on the back of your console, hold your finger on the eject button, then flip the power switch on the back of the system to the "on" position. When the fan comes on release the eject button. The fan should then go into overdrive and run hard for about 20-30 seconds. Keep in mind, if your system is pretty dirty this is going to blow dust all over everything around it,
so do it away from other electronics! Good luck...
Retrohack
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Disk Reading
Well try resetting the outlet that the PS3 is plugged into, unplugging everything from the PS3, and plug everything back in, it should work. If not, call Sony Customer Support and they will Fix your PS3 For you. Hope this helped.
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
