Despite bing properly connected to an outlet, the TV will not turn on using the remote or by manually pushing the "On" button
  • 11,361 Answers
The power supply module may have died, check the main AC fuse on the power suppluy module first.
Make and model?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 14, 2011
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Tip
Remote control codes
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
on Apr 02, 2015 | Televison & Video
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
Why does our TV go through the channell setup everytime we turn it on?
Hi Mary -
The first thing you should do is consult the set up procedures on Page 8 / Section 4 of the manual. This will assure that you have completed and exited this important section properly.
If the TV should lose power (power outage, blown fuse or circuit breaker, cord removed from the outlet, etc.) the TV will likely need to have the setup performed when powered again for the first time. Likewise, a TV that is plugged into an outlet controlled by a switch, will lose power when the switch position is changed. Since switched and un-switched wall outlets look the same, you will need to unplug the TV and plug in a table lamp or similar and operate switches to see if it goes out. You will need to try both the upper and lower outlets as they can be operated independently of each other. If you find that the outlet is switched, you will either have to stop using the switch or find another un-switched outlet to power the TV.
I didn't see it mentioned in the manual, but some TVs have a dedicated power and a dedicated on / off button. If the power button is set to off, the TV will shut off and the remote will not be able to turn the TV back on until the power button is turned back on. The on / off button on the TV allows the TV to be turned on and off with the remote - or the on / off button on the TV. Again, this will only work if the dedicated power button is on. If the power button is set to off, it may be causing the TV to lose the set up information - requiring that it be done again. Make sure that you are using the remote to turn the TV on and off - or the correct button on the TV if you do not have a remote.
If all fails, you might want to contact Sanyo directly. According to the manual, they can be reached at 800-877-5032. I hope this helps & good luck!
Jul 31, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
