Question about Homelite Garden
I havea 16 inch Homelite chain saw , I 've had it for about 25 years.I cannot not pull the starting rope. If I take out the spark plug ,it pulls with no effort.I have taken the starting rope cover off and everything looks normal.
    Sergeant:
    Champion:
  • 250 Answers
If someone put the wrong sparkplug in the saw it would do the same thing. The plug threads could be too long and when the piston comes up it hits the plug and stopps. If the electrodes on the new plug extend farther out of the sparkplug the piston will come up and hit it and the engine will not turn.
Posted on Mar 15, 2011
Switch turns off
try pulling the starting rope a little bit out before you pull start it. If this does not work replace the switch.
Sep 08, 2014 | Homelite ZR10926 16 Chain Saw
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
This saw looks new but it been in storage for years and the rope is realy tight it beraly turns once and its hard what can i do to get it to start its a mac 110 z62.1 class 1c
If your having problem turning the engine through ... remvoe the spark plug and use regular oil in the cylinder. Tilt it so that the plug hole is straight up and pour about 1 ounce of oil in the cylinder. Then pull it through with the starting rope. I would do this several times until the cylinder appear to free up. You have corrosion on the cylinder walls. The oil will help the piston and rings scrape off that corrosion. After the oil then use mixed gas in the spark plug hole and pull it through again. Make sure the gas is purged then attempt a regular start. If it has been is storage for a long time you may have to change the diaphram in the carb as they dry out and get holes in them / crack after being cycled with new fuel. Good Luck.
Kelly
Sep 07, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My stihl 041 saw very old made in germany farmboss but very low hours on it. will pop and smoke a little but not start. When I pull on the starter and it almost starts it gets very hard to pull on rope -...
Answer to 2 year old question about hard starting saw.There is a seal that goes bad and leaks chain oil into the crankcase.This will make it very hard or impossible to pull the starter rope. To start the saw,pull the spark plug, stand the saw on it's end so the bar is pointed up and pull the rope 10-15 times. Replace the spark plug and start.It will smoke for a while.To stop this from happening, always store the saw with the bar pointed straight down.
Jun 29, 2010 | Garden
Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
check that plug is getting spark (remove plug, w/ cap attached hold tip of plug on cooling fin. pull starter rope, should see spark). if not receiving gas check filter in tank, if ok procede to carb possibly add a bit of starter fluid.
Mar 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chainsaw won't start. Can't pull starting cord out
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Feb 24, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Thats a little strange.
Only thing that comes to mind is someone else had access to it and swapped out a plug that is too long for your short plug, Check plug type in owners manual.
maybe on sunday their 4 wheeler wouldn't start and this was quick fix.
Take off the chain cover or starter and see if it turns back and forth almost one full turn with a sudden stop at both ends of rotation. (Hitting plug)
if this is ok get back to me.
Bill
Feb 24, 2009 | Homelite Garden
Garden Logo
53 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
