GE stackable washer and dryer. washer will not spin. smelled something burning, could not tell if it was electrical or a belt. when I first noticed it, I opened the lid, stuck a spoon handle in the lid switch and moved the drum manually, it started to spin then slowed down and repeated this until it finally stopped. It was cycling on and off while doing this. everything else works just fine, it just won't spin. the belt appears fine. I have it in pieces at the moment.
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
SOURCE: Washer Stuck in Cycle
I checked the lid switch and nothing appears to be broken (cracked plastic). What exactly should I be looking for? Also during the agitator cycle I opened the lid and the washer stopped working. Does that mean that the lid switch is working?
Posted on Jan 14, 2008
  • 246 Answers
SOURCE: Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Posted on Jun 16, 2008
SOURCE: Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Posted on Aug 07, 2008
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Wont spin cycle at full speed
Burning smell is a slipping belt. These are tricky to get apart and diagnose but find the reason the belt is slipping and replacing it will solve your problem. Could be clutch, bearing or gearcase related.
Dec 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
My ge stackable smells like it is burning. How do I fix this?
Well, you do not mention which machine causes the smell. My concern is fire hazzard, be sure to check the dryer hose system, and DO NOT USE plactic vent hose, major fire hazzard, they make the same thing in metal and it works better....
Sep 20, 2009 | GE Spacemaker Washer and Dryer Electric...
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
There was a rubber smell, now washer won't spin.
It is possible that the bearings supporting the drum have seized
Was the machine noisy before it stopped?
If there is tension on the belts and the drum is locked then the motor will spin and burn the belts.
Aug 18, 2009 | GE WBSE3120B Top Load Washer
My Stackable washer/dryer is not operating right
Two things:
1) I would first check your water pump, if something gets in it or the water pump bearing is bad, it makes this kind of a sound.
2) If you can spin the washer drum by hand in either direction, the transmission is bad.
Good Luck!
May 03, 2009 | GE Spacemaker Washer and Dryer Electric...
GE washer stopped spinning and smell of burning out lingered
I am going through this right now and best I can tell..needs a new belt. Pop the front off of your washer (UNPLUG IT FIRST:)) and see if there are black shavings on the bottom. The appliance place where we usaully order our parts from do not carry this belt in stock so it will have to be ordered. Price from them was $19.00+ tax
Feb 28, 2009 | GE WJSR2070B Top Load Washer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
