Question about Watches
How do you change the time digitally and manually?
    Sergeant:
  • 302 Answers
Usually the digital is set and the manual portion will follow suit. However, your Fred is impossible to answer as you gave no information about what watch you are talking about. Try again with as much info as possible
Posted on Mar 15, 2011
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 | Watches
Have Rado 193. am trying to sync analog and digital time. Manual says turning crown slowly adjusts minutes. Does not - only hours change
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Dec 28, 2010 | Rado Maxi R21347712 wristwatch
How to change the time display
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Mar 31, 2010 | Nike Triax CV10 Wrist Watch
How to change clock hands
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 15, 2010 | Casio Fishing Gear Watch
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
NEED TO CHANGE TIME ON THIS CASIO WATCH DBW-30
http://world.casio.com/wat/download/en/manual/
Apr 01, 2009 | Watches
Have a casio watch with analogue and digital time.  can change analogue time but not digital time
Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS.
Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button.
Use small steal pin to push these buttons.
If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault.
Rating is very appreciated.
Jan 05, 2009 | Watches
Daylight savings time change without auto change in watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
You will need a pdf reader on your pc, you will find all instructions in there.
Mar 10, 2008 | Casio G7500G-9V G-Shock Vibration Watch
Daylight Saving Time will not set correctly
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Time change
Nov 06, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
