Hard disk has alot of bad sector , and dont want to partitioned , and dont want to format
  • 746 Answers
Use Hard Disk Regenerate software, your problem will resolve with 100% guarantee.
Best of Luck
Posted on Mar 14, 2011
  • 8,404 Answers
If your drive is large enough, don't worry about it. The drive will map those bad sectors out and not use them. If this is not happening, you can map them out yourself.
With drives costing less that $100.00 US (dont say where you live please) why not just replace it?
Thanks for your interest in FixYa.com
Drive not recordnized
Hi
please explain more information about your problem.
before any further assistance try to check it on other computers and see if its working or not if yes then take a full backup quickly,
if not then:
try replace the USB/SATA/PATA cable and check if it is working or not.
if not then:
1-this is an external drive:
1-1: it use as a normal external HDD for backing up data/movie/music/pics/etc.:
option number 1:try to fix its partition clusters/sectors with some software like easeus partition recovery or ...
option number 2:try to format it and then recover its data via recovery applications like easeus or "get data ntfs back" or...
note: in all scenarios you may lost some files or content
1-2 it is used for speed up your computer or has the MBR or EFI boot partition and has an OS installed on it:
try to fix its partition clusters/sectors with some softwares like easeus partition recovery or ...
2-this is an internal drive:
1-change the SATA/PATA cable
2-check its sectors or clusters via software (windows check disk or windows defragment option) for bad sectors or cluster issues
3-try to fix its partition clusters/sectors with some software like easeus partition recovery or ...
if none of my solution works or software found some bad sectors that could not resolve it then or even you couldn't format the drive then:
maybe it has a hardware fault and there is not much you can do about it by yourself and you should go for warranty service or replacement or asking some expert companies for recovering your data via some special hardware that it may cost you too much.
best regards
Jan 13, 2018 | LaCie Computers & Internet
Tip
How To Fix Bad Sectors on the Hard Drive
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Feb 03, 2011 | Computers & Internet
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Samsung hd154ui hard drive - cannot format above 1 TB says 500gb available but does allow one to create a partition
The drive has developed some bad sectors on it
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
or you could download partition magic
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 Partition Magic 8.0
note: after you loaded your operating system you will have to change the boot order back to your hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
Hope this helps you
Apr 06, 2011 | Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2...
How to remove bad sectore of hard disc? s/n=0415j1ftc02540
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | Maxtor Hard Drive
Received
Try deleting all the partitions and perform the complete format instead of the quick format. Maybe this will help you.
Jan 03, 2010 | Dell Inspiron 9100 Notebook
Hard disk Bad sector Problem
Bad sectors is a sure sign of bad problems down the road. I recommend Backing up all you data and replacing the drive as soon as possible. The drive is failing. Hope this was helpful.
George
Jul 16, 2008 | Computers & Internet
Hard drive problem
may be format table is mounted incorrectly ,u use the tools like partition manager,or full format the entire disk ,(NOTE:your data fully erase)then regenerate the partitions using windows installation or mentioned above,
regards
prsanna
Mar 06, 2008 | Computers & Internet
Bad sectors in hard disk
Download the manufacturer's diagnostic software, run it. Perhaps it can do a low-level format which will recover unusable space.
I wouldn't trust this drive with any valuable data, even if the diagnostic software works. The drive is probably soon to fail completely.
Nov 28, 2007 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
