Question about Intel Entry Server Board S3210SHLC - Motherboard - SSI TEB - Intel 3210 - LGA775 Socket - SATA-300 (...
Need to get sound card working on intel S3210SHLX motherboard... Any cards that work ???
  • Intel Master
  • 3,606 Answers
Try using this link:
http://www.intel.com/p/en_US/support/detect/
This utility will find the driver for you.
Or find the driver manualy from here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22S3210SHLX%22
The slot type is following:
One PCI Express* x8 with x 16 connector
One PCI Express* x 8 with x8 connector
Two PCI-X 64-bit/133 MHz
One PCI 32-bit/33 MHz One PCI Express* x8 with x16 connector
One PCI Express* x8 with x8 connector
One PCI Express* x 4 with x8 connector
Two PCI 32-bit/33 MHz One PCI Express* x 8 with x16 connector
A creative sound card, PCI type will work
Hope this was helpfull.
Posted on Mar 14, 2011
No sound on Intel 865GSA motherboard
Hello, just check in bios that your on-board sound card isn't disabled. it would have to be if you installed a pci sound card anyway.
May 11, 2012 | Intel Computers & Internet
Sound drivers are not working
if the driver is not working mean that the embedded sound card gone bad, you may need to install PCI sound card for getting sound.
you may try to update sound drivers from the intel web site
Nov 12, 2010 | Intel Motherboard
I have intel pentium 4 and windows 7. my audio devices are not working . which audio driver should i install to make it work?
Maybe your saund card doesn't work on windows 7... Which sound card do you use, or what motherboard do you use???
Aug 11, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
When i was install my windows after then sound driver is not supporting
You would need the motherboard's ORIGINAL SOUND CARD DRIVERS from it's website
First go to Chip identifyer below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=861&DwnldID=18498&lang=eng
After intel detects and identify's the chipset, it will bring you to a driver page where you can get your sound card drivers.
Reinstall your drivers according to what operating system you have: Windows Xp or Vista, or Win 7
Reboot your pc and if it still does not work, scan for viruses and run utility software and try again
If it still doesnt work, you may need to just buy a new sound card
Hope this helps
Mar 28, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How to Sound card Installetion?
I've pasted the direct link from where you can download the audio drivers for your Motherboard's integrated Sound Card... After Installation restart & hopefully you will have the sound on your system..
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/16998/a08/AUD_allOS_5764_PV_RTL.exe&agr=&ProductID=2839&DwnldId=16998&strOSs=&OSFullName=&lang=eng
Lemme know if iy works mate :-)
Feb 12, 2009 | Intel DG31PR Motherboard
Intel d865perl sound card drivers
left click this link & choose you're operating system for the Intel D865PERL motherboard drivers. (Reinstall the driver software).
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=949&lang=eng
For windows XP/home & pro. Click on this link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=949&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
After reinstalling the software & you're sound does not seem better than the built in sound chip may be going bad.
Other factors can also cause the effects you are having. Run windows system defrag. Also run windows Disk cleanup. These tools are found in windows System tools. Lastly you can buy & add a PCI sound card into an emty PCI slot to bypass the built in sound card. If you choose to do this you will need to enter the bios & disable the built in sound device.
Good Luck!
Mike
Jun 27, 2008 | Intel Desktop Board D865PERL...
Sound card not working ( no sound output ) mother board intel 810E
Go to Settings, Control Panel, Sound and Audio Devices, check "Place volume icon in the taskbar." In your Device Manager, pls verify that the drivers for your sound card are completely and correctly installed with no yellow or red markings. Likewise, verify that in your CMOS/BIOS settings, the onboard audio has been enabled. The sound driver/installer for an Intel CA810E has the filename 4035full.exe and uses a DOS component.
Should this not work, you might not have an Intel motherboard but one that just uses the Intel 810E chipset. Please post back with a more specific motherboard brand and model.
While it is true that the 810E chipset is by Intel, it does not necessarily mean that the motherboard entirely is by Intel. It could be by Asus, MSI, PCChips, ECS, Soltek or others. The sound therefore need not be the same for all versions of motherboards using the said chipset.
The Intel mb that uses this chipset carries the model CA810E or CA810 which uses Creative Sound Blaster* AudioPCI 128V audio solution or Crystal Semiconductor CS4297 AC '97 stereo audio codec;
The Asus CUWE-FX/RM, FlexATX or i810E uses the same Intel 810E chipset but different sound. Asus can and may use CMI, Crystal, Creative, ESS.
An ECS BKi810E(V7.3) uses the same Intel chipset but C-Media 8738 for sound.
An MSI MS-6188 uses the same chipset. It may have used an Avance-Realtek AC97 for sound.
Hope this be of some help/idea. Pls post back to confirm that you have an Intel CA810 version or by some other motherboard manufacturer.
Good luck and kind regards.
Nov 06, 2007 | Aardvark Direct Pro 24/96 Sound Card
Intel Entry Server Board S3210SHLC - Motherboard - SSI TEB - Intel 3210 - LGA775 Socket - SATA-300 (... Logo
180 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
