Question about Labtec ATX 5820 Computer Speakers
My labtec atx-5820 blows the fuse when I turn it on. I have the correct fuse in it. It is the right amps.
    Sergeant:
    Champion:
  • 286 Answers
You seem to have a serious problem here. You should take it to either Pc world or your local repair person. Hope this helps a little.
Posted on Apr 07, 2011
Amp blowing fuses
Then there is a defect in or on the amp, causing it to use a too high current. Stop putting in new fuses, till the amplifier is repaired or the shortage is removed. Could be a speaker cable has a shortage, or even some (older) amps could start oscillating when a speaker was removed, also blowing the fuse.
May 03, 2015 | Audio Players & Recorders
I replacsed th wiper transmission and now the wiper fuse keeps blowing I did not work on any thing but that
Does the fuse blow when the wipers are off or when you turn the wipers on? A fuse blowing means either a short circuit or an overload. Lets say that your wiper transmission is new and working properly, then an overload is probably blowing the fuse which is caused by the circuit pulling to much current because something is not aligned correctly and moving freely when the wiper motor is turned on. Before you connect the arms to the transmission, move the arm assembly manually with your hand to make sure the wipers go across and back on the windshield. This will verify that the arm assembly is moving freely and not jamming. Then turn the wiper transmission without connecting the wiper arms and see if the transmission is working properly and not blowing the fuse. This will verify that your wiper transmission is not defective. Check the wiring going to the wiper transmission for any bare spots or nicks on the wire insulation. If you have a bare spot or nick that is touching metal, the fuse will blow (this is called a short circuit). If you find a bare spot or nick on the wire use electrician tape to insulate the bare spot or nick. Usually three wraps of electrician tape around the bare spotor nick will do the job. Oh, make sure to replace the fuse with the correct amp fuse. Your car dealer auto parts can provide the information (over the phone) on the correct amp size. You can purchase the fuse at any auto parts. FYI: Too small an amp on the fuse will blow when the wiper is turned on. Too large of a fuse will cause the wiring to burn if your wipers should stop shifting and jam. Good Luck. Hope this helps.
Mar 07, 2014 | Chevrolet Cars & Trucks
LABTEC SUBWOOFER BLOWS FUSE WHEN I TURN ON SPEAKERS
see the rear side near fuse. something will be written for fuse specifications. It looks you use a fuse of low amperes.
Feb 11, 2011 | Labtec ATX 5820 Computer Speakers
My fuse blows everytime i plug in my sirius radio to cigarette lighter...why?
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
May 12, 2010 | Sirius Satellite Radio Receiver
T rg fiesta front wipers fuse keeps blowing
Are you replacing it with the correct amp fuse? Buy a couple of the RIGHT fuses and try this.Your wiper motor may be bad, or the wiper mechanism is binding, causing the motor to over amp and blow the fuse. Try lubricating, if you get to it, the arm mechanism, and make sure it is not hitting anything while it is in motoion. Not familiar with this cars set up. Remove wiper blades, or stand them up and see if it still blows tyhe fuse
Feb 03, 2010 | 2006 Ford Focus
On a lighting tower i turn on 1 light and it draws 9amps when i turn on 2 they draw 30 amps and blow 15 amp fuse why ?
Why are you blowing a 15 amp fuse or why is your machine drawing so much current?
1:The fuse is blowing because you are drawing enough current to blow it.
2: Your computer, no matter what make or model should not be drawing that much current, your wall outlet is typically 15 amps.
Your power supply is most likely the culprit and may have damaged other components of your machine i.e the motherboard.
Disconnect the computer from the outlet, open it up and inspect it for burn marks, sniff for odd burnt smells.
I think you need a new power supply at the very least and maybe more.
Sep 03, 2009 | Chieftec Dragon - Lighting Yellow...
I have a 1998 chevy blazer (s-10) 4.3L 4x4 it keeps blowing the #15 (10amp) 4wd fuse, if you put a 10 amp fuse in it will blow the minute you turn it on ,then we put a 15 amp in it seems to do it when you...
check transfer case electrical switch, sometime if it bad it will also blow the fuse. don't recommend you put any higher fuse than recommend, If the fuse blow there is a short some where and by putting higher amp fuse you might short or burn something else beside the fuse. if that check out than check your transfer case motor, might lock up and not allowing the motor to turn instead it short the fuse. don't drive the car, just leave it in park, put correct fuse amp back in and unplug transfer case electric switch and turn the key on (dont start the car) and see if the fuse blow; if not plug it back in and see if it blow the fuse. if that is not the case, unplug transfer case wire, and do the same and see if it blow the fuse.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Missing -5VDC and -12VDC
Could be.Some do some don't.Some have a circuit breaker. Take the cover off and check. Be careful though as some parts in the power supply can hold a pretty significant charge for quite a while even after the power supply is turned off.If there is no fuse or if you change the fuse and it blows again I would say a new power supply is in order. Good luck.
Dec 14, 2008 | Aspire (ATX-AS500W) (atx-as500w 12v) Power...
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
Amp blows fuses Checked out OK: output transistors, power supply.
The fuses are there to protect the internals of the AMP.....
Please check that the correct fuses are installed......
if the incorrect ones are installed then a fire may develope...
There should be a manufacturers lable on the external chassis that details the fuses to use....
Fuses now days can be slow blow or fast blow....so the correct fuses must be used.....dont increase the fuse rating past the chassis panel label...but make sure they are correct...if they are correct then the amp needs a service to determine where the peak loadings to the power supply are originating from...
Some one may have installed incorrect fuses in the past...
Cheers from YUBEUT
Nov 03, 2007 | Sonance Sonamp 260 MKII 2-Channel...
Labtec ATX 5820 Computer Speakers Logo
74 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
