SOURCE: antenna missing
Mine came off several times along with the plastic housing. I glued it back in place with 5 minute epoxy. Make sure the metal contacts engage properly and that your signal strength is at it's highest level before you apply the glue. Mines been going 3 years since glued
SOURCE: Lg vx8350 Using external antenna port.
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
SOURCE: I have signal problems. I only get a signal in certain places.
Try removing the antenna and then bend the copper connector closer towards where the screw is. This should make a big difference
SOURCE: garmin etrex legend and external antennas
You may have a radio-receiver built into your windshield screen along the top and this is blocking the unit from receiving satellite signals. Move to a side or back window and see if this solves the problem. Also, the new units with H in the description, ie Legend HCX, have stronger receivers and can receive signals inside houses and automobiles.
No, there are no external antennae available for the Legend.
