Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
Hi
I saw your answer and wondered if you could help. On my Bosch washing machine - front loader. For some reason the retaining ring/spring came off the front gasket. Nothing seems broken so I think I should be able to just put the retainer back, but it is very tricky to do. Do you have any hints or clues to this puzzle?
I very much appreciate your help
Regards I have a Bosch Nexxt 500 and can't figure out how to remove the round access panel on the front lower part of the machine. Can you help me?
Thanks
  • Anonymous Aug 08, 2008
    The small access panel on the front of the machine has a small hole in it. Push something small and round through the hole gently until you feel it touch something and push in another 1/4" past that point. Then you can rotate it to release it. Just took mine off about 1 hour ago.
  • Anonymous Mar 17, 2014
    need wiring diagram contol panel bosch nexxt washing machine
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
Posted on Jun 25, 2009
I mounted the ring by myself. Here's how:
1. Get a small piece of 2x4 that's longer than the spring will be when it's expanded. You basically have to stretch it less than an inch.
2. Nail two 4d nails to the piece of 2x4 close to the long edge. Again, about an inch or so wider than the compressed spring. Nail them so only about 1/4 of an inch is exposed.
3. File the head of the nails so they are relatively smooth to allow the ring to slide off easily.
Note: Wear eye protection just in case the spring snaps.
4. Hook one end of the ring (not the spring) to one of the nails and use a pliers to stretch the spring to hook the other end of the ring to the other nail.
5. Set the ring into the gasket groove making sure the spring is in the 6:00 position.
6. Hold the spring in place with one hand and gently push it off on of the nails. The other nail should come out easily.
This may take a couple of tries.
Posted on Feb 09, 2010
2 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Posted on Jun 04, 2008
How to replace door seal on washing machine Bosch Advantixx ?
How to Replace the Door Seal on a Washing Machine - Bosch
One of the most common faults of a leaking washing machine is a faulty seal. Thankfully replacing such a component of your washing machine is not a difficult task.
In the above video, with the help of our experienced team, we explain how to replace the washing machine door seal, and below we've compiled a simple step-by-step guide which takes you through every point covered in our video.
Step 1: To remove the door seal on any make and model of washing machine, you'll need to remove the entire front panel, followed by the soap dispenser and fascia.
Removing the panel and fascia is easy to do, once you've undone the screws holding it in place, whilst the soap dispenser should just clip out of place.
Step 2: With these components removed, clip away the kick plate, put the drain hose to one side before removing the retaining clip which holds the door seal against the front of the machine. Once the clip has been removed just push the seal inside.
Step 3: Undo the four remaining screws holding the front of the machine on, before pulling the front of the machine and the door away from the machine.
Once the front of the machine is off, you should be able to see the spring retaining band going all the way around thedrum. This should be easy to pull off, enabling you to peal the whole old seal away; once you've removed the old seal this can be thrown away, although it is advisable to keep the retaining band, as this can be reused with the new seal.
Step 4: You'll now be ready to attach the new seal, when doing so make sure that the drain holes are positioned at six o'clock; once you've done this it is just a case of working the new seal onto the drum.
With the seal worked onto the drum, put the retaining spring into its little ridge, before giving the seal one final check.
Step 5: Reattach all the parts back to your washing machine, attaching the door seal to the front of the machine ensuring that it goes over the lip, before attaching the retaining band on the bottom and sides.
There you have it, a step-by-step guide to replacing the door seal on a washing machine, helping it to perform to its optimum level.
SAJID
How to Replace the Door Seal on Washing Machine Bosch
Feb 17, 2016 | Bosch Washing Machines
The door gasket is twisted, how do I fix it?
There is a metal retainer with a spring on the outside of the door around the seal remove that and re-form the seal around to door panel and secure with retaining spring. If this doesn't help you will have to replace the seal.
Feb 12, 2012 | Miele Touchtronic W3033 Front Load Washer
I need help replacing the front door gasket and seal
Bosch WFMC3200 Front Load Washer replacing the front door gasket and seal.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Bosch WFMC 3200 Front Load Washer
I replaced the door gasket on my bosch 3200 washer and it leaks water when finished
If oit has only started to leak since you changed the door gasket, then it suggests to me that it is not fitted correctly.
make sure you have the inner retaining spring or clamp securely fastened .
Jan 11, 2010 | Bosch Washing Machines
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Thanks.
Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
May 01, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
2,666 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
