Mitsubishi WD-73C9: my picture is dim(can hardly see). lamp light is green. i replaced the lamp and i still have the same problem. any ideas?
    Master:
  • 691 Answers
Dim light check first make sure lamp was correct lamp for you model, most time it's worth buying lamp and enclosure to make sure lamp is correct then also it could be ballast problems.
Posted on Mar 14, 2011
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
There is sound but no picture
The board that connects to the bulb is the ballast. If it's bad then it won't fire the bulb or will cycle it on and off.
Jan 13, 2015 | Mitsubishi 915b403001 Lamp For Wd-65737...
Mitsubishi wd-73c9 73" dlp tv
Here's what the Manual says about light codes for this TV. See Picture of actual page from manual.
Apr 13, 2014 | Mitsubishi WD-73C9 73" DLP TV
Wd 73c9
You need to replace the TV projections lamp.
The lamp part number you need is 915B403001
Once you have replaced that lamp your TV will be bright once again.
Jul 29, 2013 | Televison & Video
Green flashing light
the green flashing light does not make sense if set is working.
As far as a dark picture if lamp not replaced or replaced with a generic it may be nearing the end of its life, many will dim just before failing.
Dec 05, 2012 | Mitsubishi WD-60737 60 in. HDTV
My Mitsubishi TV is flashing a green light and gos to the blue welcome screen,does anyone kno what wrong with my tv?????????
I have an old Mitsubishi Tv , your instruction manual is good and thorough and if you don't find it there check online with http://www.mitsubishi-tv.com/ use the support section there.
Jul 14, 2012 | Mitsubishi WD-73C9 73" DLP TV
I have a model WD-73C9 Mitsubishi. When i turn it on after about 30 sec it turns it self off. I performed the test code with the Imput and Menu buttons and the green light flashed 3-4 could you help with...
On 2006,7 USA models DLP, this means lamp shutting off unexpectedly. Which could be a bad lamp, lamp driver(ballast), or loss of 'on' signal from engine. Lamp or driver are more common. I'd guess ballast if lamp looks good and is newer (less than 1000 hours on it.)
Apr 12, 2010 | Televison & Video
Lack of red tones in the co;or
In ur remote push the menu button.Got in menu Picture go down to reset.Push it should reset back to factory setting.
Mar 17, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
Electro Med Services...
