Question about Kenmore 23022 Top Load Washer
Kenmore Elite Top Load Washing Machine Model Number N-23022LR. Does not spin or agitate and makes a noise like it's grinding.
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
  • 223 Answers
SOURCE: my washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Posted on Jan 20, 2009
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
This Kenmore Elite Top Load Washing machine has
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Sep 26, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
remove cap,,or fabric softner dispencer..pull straight up..look down in the agitator you will see a plastic cover,,pull it straight up...now your looking at the agitator dog cam assmbly..thats a 1/2 in nut there,,remove it you will need a nut driver or wrectet...now just pull the hold agitator up...be careful not to lose the agatitor dogs..onthejob
Jan 17, 2009 | Washing Machines
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Kenmore 23022 Top Load Washer Logo
60 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
