Question about Sharp R-1214 Microwave Oven
Does not cook - no fan, no heat - Sharp R-1214 Microwave Oven
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Posted on Mar 14, 2011
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
The light and fan continue to run after cooking.
open the microwave cover & check micro switch attached with door lever.it may be displaced or damged. replace it
Apr 25, 2014 | Samsung SMH9187 Microwave Oven
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
I have a GE SpacesaverXL model JVM1350BW. It does not heat up. The interior light, surface light, fan, clock, keypad all work normally. When a cooking mode is chosen and START is pressed there is a...
I wouldn't worry about the sensor error right away.
Sometimes that's just caused when the door is opened before steam could be detected or steam was not detected in the maximum amount of time.
Once it's all working again, if you still get the error regularly, it may be a bad humidity sensor.
If the internal cooling fan IS running when you try to cook AND the oven is not heating, it's probably a failed secondary interlock relay on the control circuit board.
If the internal cooling fan is NOT running when you try to cook AND it's not heating, the bottom door switch is probably the culprit.
Here's is a file on checking and replacing door switches.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Listen to that very carefully, and listen to yours to see if the cooling fan is working.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let me know if I can help you further.
Aug 22, 2010 | GE JVM1350BW/WW/AW/SY Microwave Oven
Won't heat or cook. Has power, light and clock work, Fan comes on when you push cook button but the carousel doesn't turn and it doesn't cook
Microwave Oven Basic Troubleshooting Tips
heatman101
jhfjk
Jun 29, 2010 | GE Countertop Microwave Oven
My fan kicked on by itself and won't shut off
The over the range microwave hood has a heat sensor in it. If it senses hot temperatures from cooking below it will turn the fan on. The fan will turn off once it cools down, this is to protect the microwave controls from damage.
May 08, 2010 | Magic Chef CMV1100 Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
No fan noise when cooking.
The internal cooling fan is critical. It comes on automatically whenever the oven is cooking.
If the oven is used without its working properly, the magnetron can be destroyed very quickly.
(This of course is different from the hood vent exhaust fan, which you can turn on and off at will)
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In some models, the motor itself is bad. In other models, it is a bad relay or connection on the control circuit board.
We regularly repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly (with your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1214 Microwave Oven Logo
81 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
