Have a 10yr old 37" Zenith, went dark and emits a buzzing noise and see smoke from something frying (seems to be from lower right side as you look at the back of the set). A lot of dust build up over the years (hasn't really been moved, exterior cleaned only) Going to take in for service, does it sound like it might be the picture tube or probably a short somewhere? Anyway an electrically challenged person such as me can tell the seriousness of the problem?
  • John Kampa Aug 05, 2008
    Dan- thanks for the help already...
    Zenith Model # Z36H320 built in 1997.
  • 4,234 Answers
The flyback transformer has a short inside of one of the windings and needs to be replaced. This part if still available will be in the $75 range. This set may not be worth the repair cost. If you want to get more specific costs, please post the exact model number from the back of the set.
Posted on Aug 01, 2008
Realistic pro-62 scanner emits high frequency buzzing noise after half hour or so of being switched on?
There is a problem with something breaking down in power supply side. It could be a filter capacitor or a semiconductor.
Apr 18, 2013 | Radio Communications
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
I have a Maytag refrigerator model# PTB1953GR, (probably well) over 10 years old, with upper freezer, lower refrigerator and no icemaker. I am a "snowbird" so that it is unused and unplugged for...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jul 16, 2011 | Maytag Refrigerators
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
Jul 13, 2011 | Sanyo DS25390 TV
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
TV made a poping noise and the screen went dark. Turns on but there is no image and wont turn off.
a capacitor on the DM or convergance board has fried and will need to be replaced. You can use a multi-tester or capacitor tester to test each one. Also look for black burn marks and swelled or black capacitors
Jul 09, 2009 | Vizio VOJ370F 37 in. LCD TV
10yr old bryant 90 series
Something is shorted out somewhere in the system.
You will have to trace down each component to find the short if it can't be found with a visual inspection.
Does the board have a low voltage fuse on it?
Dec 17, 2008 | Kitchen Appliances - Others
Zenith A27B41W
I dont see this model number under PTS corp list of Zenith's modules. But a service manual is available from For a download. If you know how to work on solid state electronics, then you should have no problem with this repair. If your a handi person, a TV set is no place to be experimenting around inside of as it can seriously kill you. Find a trined tech to assist you with this. Good Luck
Aug 26, 2006 | Zenith A27B41W TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
