Question about LG Side by Side Refrigerator w/ LCD TV and WeatherPlus Information Center - LSC27990
I want to limit the door travel on my refrigerator so it doesn't hit my counter top when it is opened.
I have a kitchenaid refrigerator with single door on top and pull out freezer drawer on bottom. When I open the refrigerator door it will swing all the way open and hit the counter top . How do adjust it...
It sounds like your refrigerator is out of level in the direstion of your door hinge. Under the front side, in behind the louver at the bottom will be two adjusting screws. Either raise on the hinge side or lower on the non hinge side. Or both. this should get the door to the point you should be able to let it loose and the door should, from any position, shut by itself.
Hope this helps.
Dec 19, 2014 | KitchenAid Refrigerators
How do i set the travel limits on my craftsman garage door opener 139.53919
  • Open the garage dooricon1.png fully by pressing the wall control button. The bottom section of the door should be right at the header in the "full open" position. If it is too far back, the door cable can become misaligned. If it is not back far enough, you may not be able to get your vehicle in and out of the garage.
  • 2
    Position a stepladder behind the garage door openericon1.png motor. Locate the limit adjusting screws on the left side of the motor housing. Have a friend stand by the wall control button.
  • Sponsored Links
  • 3
    Insert a screwdriver into the slot for the "up limit" adjustment screw. Turn it to the right to decrease the door travelicon1.png and turn it to the left to increase it. Turn the screw in small increments.
  • 4
    Close the garage door by having your helper push the wall control button. Notice the seal between the door and the floor--there should not be any light coming through. Adjust the "down limit" screw in the same way if necessary.
  • 5
    Operate the door by the pressing the wall button and check your adjustments.
  • Read more: How to Adjust a Craftsman Garage Door Opener ' eHow.com http://www.ehow.com/how_5419011_adjust-craftsman-garage-door-opener.html#ixzz2Hm1tx0a0
    Jan 12, 2013 | Sears Craftsman LiftMaster Chamberlain...
    Door will not stay down. goes to bottom then cycles up. disconnected bell wire from wall controller problem repeated using wireless remote.. the sensors at bottom of rails one is green other is yellow,
    Color of sensors doesn't matter. If your door is hitting the floor and then reversing it is traveling too far in the down direction. Locate the 'down limit' control on the side of the motor unit and turn this control a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
    Jun 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
    Garage door loses travel settings after a day or two.Door closes then reopens after hitting the floor.I made the proper travel adjustments on the side of the unit then after 1 or 2 days the door hits the...
    I have been having almost the same problem. My up limit setting is changing. I intend to replace the limit switch assembly. I know of nothing else that can cause this problem.
    Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Hello! My side by side Fridge door won't stay
    sir i have a problem my flash player run very slow
    Apr 19, 2010 | GE Refrigerators
    The refrigerator door swings open without resistance and hits the counter behind the door
    Hi, Check the hinge cam and closer kit on the bottom hinge. See if there are any cracks or even part of the cam mising. They have a tendency to wear sown through the years. If this loks like the problem, please let me know and I can get you part #'s for you.
    Vid
    May 23, 2009 | Refrigerators
    My door opener is new, Chamberlain, mod cg40cd, the drive will hit both limits. will not let me set the up and down limits, doesn't seem to matter whether I set the up and down to max either way??????
    THE TRAVEL ADJUSTMENT IS ON THE SIDE.
    YOU MAY BE ADJUSTING THE SENSITIVITY (TRAVEL LIMIT HAS NO MAX ADJ.)
    BE SURE TO RESET THE SENSITIVITY ADJUSTMENT TO ABOUT 1/4
    HOPE THIS HELPS
    Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Counter depth refrigerator
    Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
    Let me know if this works for you.
    Thanks,
    Bill
    May 16, 2008 | Refrigerators
    LG Side by Side Refrigerator w/ LCD TV and WeatherPlus Information Center - LSC27990 Logo
    358 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
