Question about Cell Phones
I am trying to find the user manual for the ESI Blue Goose Bluetooth Car Kit
2 Suggested Answers
  • 8 Answers
SOURCE: trying to connect Nokia 5800 to prowave bluetooth car kit
you have to make your phone visible to other devices. to do this, go under settings, make sure bluetooth is on, then adjust the visibility of the phone Settings
Select Menu > Settings and Connectivity > Bluetooth.
When you open the application for the first time, you are asked to define a name for
your device. You can change the name later.
Select from the following:
? Bluetooth — Turn Bluetooth connectivity on or off.
? My phone's visibility — To allow your device to be found by other devices with
Bluetooth wireless technology, select Shown to all. To set a time period after which
the visibility is set from shown to hidden, select Set visibility period. To hide your
device from other devices, select Hidden.
? My phone's name — Edit the name shown to other devices with Bluetooth wireless
technology.
? Remote SIM mode — Enable or disable another device, such as a compatible car kit
accessory, to use the SIM card in your device to connect to the network
Posted on Mar 23, 2010
Hi how do i connect my samsung to my parrot blue tooth,im using my sons phone but will be getting a sansung s3,athe moment im using a s3 mini
Try 0000 or 1234 as the pin number or get the pin number from the instruction manual that came with the Bluetooth Car Kit (under "Pairing with your phone").
Hope this helps.
Nov 13, 2014 | Parrot 3200 Ls Color Handsfree Bluetooth...
I don't have the manual anymore and I forget how to pair the blue trek car kit with my phone. Please help!
Try this:
1. Put them close together
2. Switch on phone and select bluetooth discover mode (make sure it's visible to other devices)
3. Switch your BlueTrek device. Press and hold both Talk and Vol+ button for about 5 seconds until the indicator light flashes red and blue alternatively and sound can be heard from the speaker.
4. The phone should then detect the Bluetrek device. Follow the instructions from the phone to accept the pairing request. If you didn't change it, the PIN code should be 0000 (zeroes).
Hope this helps.
May 04, 2011 | BlueTrek Surface sound Duo Bluetooth Car...
Turn on the bluetooth
Turn the bluetooth car kit off, by pressing the MFB for some seconds. Now, press and hold the MFB until the blue and red leds blink simultaneously. Then, if your phone's bluetooth radio is off, turn it on, and make it search for other devices (check your phone's user manual for further details). When the Visor Drive is shown, select it to be paired, and if a pairing code is requested, enter '0000'.
Hope it works for you.
Cheers! Carlos
Apr 22, 2010 | Handspring Visor Prism Handheld
MOTOROLA IHF 1000
You need to pair the carkit with your phone. Make sure the Bluetooth feature on your phone is set On, then follow the Pairing process outlined in the user manual.
Jan 02, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Blueant Supertooth Light Bluetooth Speaker...
How can i reactivate my blueant blue tooth on my motorola ic902?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Code for bluetooth car kit
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
Nov 24, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Sony handsfree blue tooth handsfree hcb 400
go to sony ericsson web site and you can down load the user mannual
Oct 18, 2008 | Sony -Ericsson OEM HCB-300 Bluetooth...
Cell Phones Logo
509 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
