Question about Powmax Computers & Internet
Good afternoon, i need powmax datasafe 420VA monitoring software
How to restore eztune
Funny you should ask. I was just reading my Gateway monitor manual this afternoon and it says you can download EzTune software from http://oem.portrait.com/dtune/gwy/enu/upgrade.html. Be sure to to download the right software for your monitor. Apparently there are different versions for different monitors
Dec 17, 2012 | Gateway 19" Widescreen Flat Panel TFT LCD...
Dell datasafe local activation code.
Serial key for: DataSAFE 1.22
name/Home User company/Home User #/06059678 or name/ReaPeR company/ReaPeR #/04266565 or name/Safe_From_No_One company/Safe_From_No_One #/09395460 or name/TFT97 company/TFT97 #/02414524
Landmark Datasafe crashp v2.0 for Win
51818L1
51818L1
hop it helps
Apr 19, 2012 | Dell Computers & Internet
ST log.dll not working. Can you help ?
This is a problem related to "Dell DataSafe Online" system. Have you ran a Cleanup tool (Specially McAfee)? You have to be careful when you use Cleanup utilities or Registry Cleaners. Because they are extremely dangerous if not used carefully since they would delete Shared and Using Registry Entries and Files without letting you know.
  • Have you tried to do a System restore? If you didn't please do.
  • Just type rstrui in the "search box" and press enter. Its a simple process. Restore the machine back to a date which the utility was working fine. You can select the "Recommended Store" or a Store Point of your choice.
  • Or you can do the following. But you has to have the Software with you.
  • In your software, try to locate the Stlog.dll file. If you have found it you have to copy and paste it here.
  • %ProgramFiles%\Dell DataSafe Local Backup\Components\ProtectRP\Stlog.dll
  • Lets re register the DLL file now.
  • In the "search box" in the "Start Menu", type cmd and hit enter.
  • Type this and hit enter.
  • Regsvr32 Root:\Program Files\Dell DataSafe Local Backup\Components\ProtectRP\Stlog.dll
  • Root is the Partition which you have installed Windows on. C is the default.
  • You will see a Success message. If so, the DLL is registered successfully.
  • If you were unable to locate the DLL file or unable to do a System restore, you have to uninstall and reinstall the program or you have to stop Loading it when the Computer Starts.
  • Type msconfig in the "search box" and hit enter.
  • Go to the "Startup" tab.
  • Check for the Specific Software (Datasafe) or related components. Clear the Check Boxes. Then it will not be loaded again. Most probably it will be STServices.exe
  • You can uninstall the program using the Control Panel. But not sure whether it removes all the Components.
Feel free to contact me again.
If your problem got solved after following these steps, please be kind enough to RATE the answer as well.
Have a good day and thanks for contacting Fixya!
Jul 20, 2010 | Microsoft Windows Vista Home Premium...
Sound skippes when ever playing a dvd or an aduio file
if you have dell datasafe installed in pc, kindly update to latest version of dell datasafe.
if no dell datasafe installed, upgrade firmware for your optical drive from suppot.dell.com
download and run piotodma.exe from support.dell.com
Jan 29, 2010 | Dell OptiPlex 760 MT Desktop Computer
How to stop start up error " STlog.dll not found"?
See: http://forums.techguy.org/all-other-software/849895-solved-st-service-exe.html
which states (after my editing):
The problem is related to DELL DATASAFE LOCAL BACKUP on your machine. It's the backup program that comes with your DELL.
STservice.exe is an unimportant part of this backup program.
It's just the scheduler. You won't need it.
The problem consists in the fact that the program can't find
its resources.
It seems to me that you cannot download DELL DATASAFE LOCAL BACKUP from any site on the internet.
Here is my solution:
1. If you can find DELL DATASAFE LOCAL BACKUP on the DELL DRIVERS AND UTILITIES CD that comes with your Notebook, Uninstall the whole program, ... and install it again from the CD.
Nov 20, 2009 | Microsoft Windows Vista Home Premium...
The STLog.dll is not working
is "he stlog.dll not found?
try to use registrasi cleaner software u can download these from http://registrycleaner.onlinedownloads.org/
or:
http://www.softpedia.com/progDownload/Free-Registry-Cleaner-Download-63899.html
http://www.amltools.com/download/regcleaner.exe
if his not work, if u using "Dell Datasafe software" go to control panel --> add remove programs and uninstall it
hope these solve ur problem.. good luck:)
Sep 24, 2009 | Computers & Internet
How can i reinstall STLog.dll
DELL Computer Owners: This is primarily a problem with Dell Computers, 15** series and up with the installed "DataSafe Online" software. You must uninstall all DataSafe Online software (usually three separate programs in the Windows Uninstall/repair prgrams list you access from control panel), then if you desire to continue to use it, reinstall the software with the disk that was provided with your computer.
This comes directly from Dell advanced Tech Support. Let me know if it works for you as it has me.
Aug 12, 2009 | Microsoft Windows Vista Home Premium...
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
Powmax 4oo, no video to monitor
a dead short is the cause. or a bad ground., which wilkl lead back to a short
Nov 27, 2007 | Powmax LP-6100D (641272604024) 400-Watt...
TOLL FREE NUMBER
Not sure of a toll free number... but their RMA page on their site has this info -
Inquiry - rma@powmax.com
Phone 626-839-5955  x143
Fax 626-839-5966
Come from this page here - http://www.powmax.com/NEWARRIVAL_PRODUCT.htm
Oct 29, 2007 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
Top Powmax Computers & Internet Experts
David Payne
David Payne
Are you a Powmax Computer and Internet Expert? Answer questions, earn points and help others
