Question about Hotpoint Ultima WF860 Front Load Washer
What is error 31 in hotpoint ultima extra washer drayer
  • 1,998 Answers
This is a motor error code as shown on this site http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
if when you run the program the second time the error still persists you would test the motor and the motor control board to assure which is the problem area if you have any further questions messsage me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 14, 2011
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error message 31
Error 31 : you need to re-boot system do this by unpluging from wall leave for 5 min plug in and then switch on again this often is enough to re-boot, as it is normaly just a glitch and not a mechanical problem
Jan 10, 2010 | Hotpoint Ultima WD72 Front Load...
Need wiring diagram to conect pcb to a hotpoint ultima extra wma66
www.selfix-uk.co.uk for manuals on WM & WMA machines including wiring connection charts
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD72 ERROR CODE 31
Hello mazsmith,
Welcome to fixya,
You said, COULD YOU TELL ME WHAT THE PROBLEM IS ?
E31= Motor Drive Problem -
Run the programme again,
if problem persists call for
a Service Engineer.
I will tell you a secret.
Try unplugging the washer for 5 minutes and then we will see if this has reset the system!
like rebooting your computer.Some times it is only a glitch and no mechanical problems are there!
If so you saved a service call.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank you.
Waiting for your results!
Sep 29, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
