Where can i get a new diaphram for my rinnai bu150-04700.the rubber seal split in the cold weather
    Brigadier General:
  • 4,736 Answers
Any authorized Rinnai dealer either has it in stock or can get one, pronto.
Posted on Mar 14, 2011
No water on the hot side of line. Have rinnai gas tankless water heater. 22 degrees last night but had pipes wrapped. Have cold water pressure but not pressure on hot side. Tried to thaw pipes
You will need to have heat in the room to thaw pipes . Cold will come in from flue pipe and freeze pipes . its a slow thaw so pipes don't split .
Jan 18, 2018 | Rinnai Water Heaters
I have a 2001 Pontiac Sunfire and every time it rains or snow in the cold weather all the doors freeze shut what can i use to stop this
Get a can of silicone spray from your local parts store. Spray a rag liberally and wipe down all of the rubber gaskets that seal the doors to the car. The silicone spray will keep ice from freezing the seals to the door.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Dec 02, 2010 | Pontiac Sunfire Cars & Trucks
Trunk lid wIll not latch when it is cold. I can get it to latch after several attempts at closing it.
I would guess it needs a latch adjustment. The rubber trunk seal gets firm with cold weather.
Nov 01, 2010 | 2006 Audi A4
Well its not really the fuel tap that im looking to change but the diaphragm need changing so can someone explain to step by step to changing the the diaphragm?? and do i need a special silicon or oil to...
Hi Im not 100% certain what the hyosung diaphram looks like, but most are held in with 4 small screws holding the plate where the vac line goes. There will be a spring and plunger activated off the centre of the diaphram. This should come with the new diaphram.
You will need to remove the fuel tap first, or have the tank upside down on something soft.
You are only dealing with a few screws and a couple of parts, so just go slow and remember how it came apart.
a thin smear of rubber grease my help fit the new diaphram, do not use silicon, it can stop the diaphram moving and is not petrol proof
Aug 10, 2010 | Hyosung Comet 250 Motorcycles
I bought a Vigoro deluxe water timer last spring, it worked fine all summer. This year I can't seem to get it to work, I hook it up to the spicket and the water runs thru the whole thing and in on the...
I had the same problem with several of mine. So I tore one apart. The problem isn't that the valve doesn't close. The valve uses a rubber diaphram that flexes in and out, sealing off the water supply. The rubber diaphrams develop cracks, allowing water to pass through the valve. The rate of water flow depends on how large the crack is. The crack will become larger over time as the valve moves the rubber diaphram in and out. The diaphram can be easily replaced. However, these units are not designed to be taken apart and repaired and I can't find a replacement for the diaphram. The bottom line is that once the diaphrams crack (and my experience is that they all do within 1-2 years-time), you have to throw it away and buy a new timer.
Jun 14, 2010 | Garden
One valve of my Vigoro timer will not close completely. It's been in use since about March. Could it have sand lodged in the valve? Can I fix it myself?
Sep 26, 2009 | Garden
My 1999 Malibu sunroof works when the weather is fairly warm but during cooler temps. the sunroof will partially open and not close.
Its probably sticking on the rubber seals, when warm the rubber is pliable, when cold it stiffens up, try cleaning the rubber seal with alcohol, when cleaned put some armor-all on a rag and wipe the seal down with it, also some silicone spray helps...
Aug 22, 2009 | 1999 Chevrolet Malibu
2.8 Diesel Pajero Cold start
Have replaced your glow plugs?They dont cost alot to replace,try this
Jun 22, 2009 | 2002 Toyota Land Cruiser
99 CBR 900 Front fork seals
If the seal has been cracked by the cold weather it should be replaced. For someone mechanicly inclined and with the proper tools this is not a hard job. For the novice it can be one of those times you could have sent it to the shop and spent less time and money, and gotten better results....
As to a seal conditioner, the seals today are generally made of synthetic material. No "conditioner" will work. If the seal is made of rubber you have a 90% chance that a product called 'MARVEL MYSTERY OIL' will solve the problem. This prouduct was created in 1917 and marketed in 1923. Google the product name for more hystory and uses today. Basicly, the oil causes rubber to swell. This tightens seals and thus fixes the problem. Most any good auto parts store has this stuff on the shelf. By the way, if the bike was purchased new, wouldn't this be a warranty repair?
Mar 11, 2009 | 1994 Honda CBR 900 RR Fireblade
2004 Toyota Sienna sliding doors don't open in cold.
You could try surf board wax or spray crc on a rag and wipe the seals.
Dec 18, 2008 | 2001 Dodge Ram Maxi
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
