Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Error number = 6019 Get this message which won't
Error number = 6019 Get this message which won't go away on the monitor: error! video index save error for main image partition--error opening image control file. System operation may fail, miage data may be lost. Note error number = 6019 and call Dedicatd Micros.
  • 3,278 Answers
Its a hard drive fault. change thye hard drives. and instal new firmwear. hard drive have to be formated to FAT32. download softwear from dedicated and the 3 files to the new hard drive you are going to use as master first file is Boot and other two files no note pad or think its dv softwear. put the hard drive in cctv, then turn on should boot up and the add the files to its system from the zip file. after it has finished it will set up slave drive. down load the manual as well so you can rest the system for how many day to record for and save video for how meany days etc.
Posted on Sep 15, 2013
2 Suggested Answers
SOURCE: Error! Video index save overdue
use ur brain
Posted on Nov 17, 2010
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
My e machines home computer won't come out of.
Power save mode is just the message a monitor will display when there is no video signal from the computer to the monitor.
If the computer has no lights the problem is most likely the power supply and it will need to be replaced. Pretty easy to do, youtube it for tons of videos.
It also could be the motherboard is bad. I would start with the power supply first.
Dec 02, 2012 | Computers & Internet
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
Disk Problem - may be wrong FAT version suggets using monitor ro reformat disk. prior screenc showed message regaridng error 6019 (that was before my bosses started fooling with the system)
sounds like hard drive fail. take the hard drive out and put on a PC as a slave setting. if the PC picks it up, if it does go to my computer and check hard drive for faults using windows tools the hard drive should be in FAT32. if it will not read in window or ask's to be formated. it has lost is FAT32 format. now it can be remormatted but you will need a FAT32 format softwear as windows dont use this now in there firm wear. down load the firm wear from dedicated micro web site. and put the 3 files on the hard drive boot folder zip file and another one cannot rember name not dv file think it say or the not pad just the 3 files. put hard drive back in as master again. and turn on it should restart. will take a bit longer as it will be opening the zip file and loading the softwear. when its done then you can sort out the setting in the menu etc for record etc.if hard drive has failed and no repairable format it 2 FAT32 and do as above with 3 files. should be fine then. allso in the site is a manual read this for the setting.... think 6019 is hard drive fault
Sep 01, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Its hard drive fail. on a wright error cannot read the file. hard drive will need replacing or re formatting can happen with power cuts so would check the cpu aswell.
Jun 20, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
When I press the buton on/of ,I see the message SERVICE REQUIRED CALL 800-9357763 and than when I press the buton - at CH.4 I see the message RETRYS EXCEEDED CALL 800-9357763 can you help me with this...
The best advice that anyone can offered to you, is to do what the error message tells you to do. Follow the instructions and call the number. It's the Customer Care Dept of RS Medical, the manufacturer of your product, which oddly enough isn't a Blood Pressure Monitor. Since it's a toll free number, it won't cost you anything.
Apr 15, 2011 | Health & Beauty
Why WebSpeed error from messenger process (6019)
The Web Application you are using is written using Progress Software's WebSpeed product. The error 6019 is a generic error saying that the part of the application residing on the web server (the messenger) is having trouble communicating with the part of the application residing elsewhere. There should be a clarifying error message below the 6019 error that gives more information to the application developer. As a user you won't be able to solve the problem, it's something the application developer or at very least the webmaster of the website you're using needs to be informed about.
Aug 26, 2009 | Dell Computers & Internet
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
Kenwood ddx-6019 password
Contact Keenwood, they may make you send it in and charge a fee. Goodluck.
Feb 28, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Televison & Video Logo
371 people viewed this question
Top Dedicated Micros Televison & Video Experts
Electro Med Services...
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
