Question about Blendtec Extra Carafe / Jar for the Total Blender (Blend-Tec) Blender
There wasnt' an owners manuel with the Blendtek Mixer/blender II combo that I purchased...may I get one?
What is the difference between a mixer and a blender?
Kitchen appliances will and always will be an essential part of our life. Whether you are a culinary chef our a Permanent house chef :P Hand Blender, Food Processor, Stand Mixer and juicer mixer grinder these appliance will always be a part of your life. With these appliances you can tackle various kitchen chores with an ease; saving you an ample amount of time.
here you can know more
KitchenAid 6 QT Mixer
Oct 17, 2016 | Blenders
How do i purchase new beatters for my mixer
I would go online to the manufacturer. You might also try an appliance store that handles mixers
Nov 24, 2014 | Applica Black And Decker 250w Power Pro...
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
Aug 21, 2011 | Vitamix 5000 Work Top Blender
My mixer is making a noise when mixing and the whip attachment if hitting the bottom of the bowl which it never did
Check the assembly of the impeller. I know this is obvious, but take some time and look at how it supposed to go together... I know I become complacent on this "easy" stuff, but that blender can go together more than one way, and it's best to step back, read the owner's manual, and try again. Answer back if you have continued problems.
Nov 26, 2009 | KitchenAid KSB5 Professional Stainless...
Hand Blender does not work
If it is under warranty, then return it to the place you purchased it. Or call the toll free number and ask where local repair shop is. I am personally unaware of a repair shop near Cedar.
Aug 25, 2009 | Toastmaster 1740 Handheld Blender
Oil Leak-Stand mixer
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Will kitchen aid purchased in USA work in australia?
The Australian outlets will zap that blender - you need to purchase a 240V to 120V transformer in order to make it work.
Mar 30, 2009 | KitchenAid KSB560WH 5-Speed Blender
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blendtec Extra Carafe / Jar for the  Total Blender (Blend-Tec) Blender Logo
56 people viewed this question
Top Blendtec Blenders Experts
eyecam
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
