Question about HP Deskjet 6940 InkJet Printer
Printing envelopes Envelope is pulled into the printer then is just sits there and the red down arrow and the two ink cartridge indicators starts flashing. When I hit the red arrow it prints ok.
  • Anonymous Sep 12, 2008
    Have the same problem.
If you are printing from MS Word - go into Tools - Letters and Mailings - Labels and Envelopes, Envelopes Tab, Options, and turn off the clockwise rotation check box. Seems to work for me.
Posted on Oct 16, 2008
Why is Lexmark Pro705 printing envelopes in red vs. black?
Try to do a printhead cleaning operation.
Possible that there is not enough black ink in the printhead.
Oct 06, 2014 | Lexmark Prevail Pro705 Wireless All-In-One...
Ink light won't go out
It was a problem with the black ink cartridge. I changed it and the printer is working fine.
Oct 05, 2009 | HP DeskJet 932c InkJet Printer
LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Can't Print Envelopes, No Ink being used
Set tray 1 for the correct size envelopes in printer properties.
Feb 21, 2009 | HP LaserJet P2015dn Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Aug 31, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Printing return address on #10 24lb regular envelope
Are you free hand addressing or are you using "Word - envelopes and labels" tool. It should be goof free. If you are, check the pull down rollers on that end of the printer for damage or contamination. When you lift up the cover like you're installing a new cartridge, you should see the black rollers. Clean them with a q-tip and alcohol, wiping across while rolling it with your finger. If you're not using Word, pull down the tools tab and select letters and mailings, then envelopes and labels.
Jun 29, 2007 | HP PSC 1510 All-In-One InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
374 people viewed this question
Seeker5211
Seeker5211
