Question about Avaya 5400 Series 5410 Phone
Hi, I have the 5410. I seem to receive all external calls into our office (c. 20 people). We have a 'switchboard number' plus direct dials. I presume it's the switchboard numbers I keep receiving. Another phone also receives these which is fine, I just need to stop them coming through to me. Thanks you in advance, Rob
    Problem Solver:
  • 19 Answers
PLEASE CHECK THAT YOU ARE NOT PROGRAMMED AS THE MAINS OVERFLOW.
Best regards John
Posted on Mar 14, 2011
Do I need to dial 9 before entering the telephone number
If you are a home user, then no. If you are in an office that has a switchboard and the fax uses an extension from the switchboard then yes ( it may on some systems be a 1 or a 3 instead of 9).
If you are in an office and the fax has its own line then again no. Its easier to just an ordinary phone into the socket and see which way works.
Jun 29, 2014 | Canon Pixma MX452
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
Jul 15, 2011 | Avaya 5400 Series 5410 Phone
This issue just started this week with our Avaya 5420 phone system. When anyone in the office goes to make an outbound call, we dial the number, then receive a long silent pause and them sharp beeping...
You have a dead line somewhere. When you dial 9 it looks in a group of trunks for a call to go out on. Test the dial tone of all the lines. If that isnt it. There might be a problem in the ARS routing.
Dec 29, 2010 | Avaya 5400 Series 5410 Phone
Hi Expert I have a phone mode is 5410, When I t...
Call a tech. There is a batch file that needs to run and the phone updated....
Pretty advanced IP Office programming
May 20, 2010 | Avaya 5400 Series 5410 Phone
Verifone Omni 3750 - ''Please try again - LC''
Is the hotel line going through a switchboard? If so you might need to add a 9 or whatever number is required to dial an outside line, to the number it tries to dial.
Or maybe it's the opposite. Maybe at the office it's dialing out and it's set up that way and at the hotel it might be a direct line and you will need to remove the 9 or whatever number is required to dial an outside line.
Or the line quality is too low.
Or maybe you need a microfilter if the line has adsl broadband on it.
Dec 01, 2009 | VeriFone Omni 3700 (M19745014US1) Magnetic...
How do I change the caller id number for my phone
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.
When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you wish to program OLI on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
Press the next key 5 times (bottom right arrow) .
The display should say OLI #.
Press the Chng key and enter in your DID number,
Press ok when finished.
Press the release key when done programming.
Oct 05, 2009 | Nortel T7316E 2-Line Corded Phone
I would like to forward all calls to my cell phone
Which system do you have? IP Office?
If so, at your phone, you need to set the number to forward to:
Press: *07*9xxxxxxxxxxx#
(where 9xxxxxxxxxxx, is the dial "9" access code to dial outand the number how you would dial it, followed by pound)
so for 555-111-2222...
*07*915551112222#
Once that is done, you need to turn forwarding on:
*01
To turn forwarding off:
*02
Upon entering the codes, you will get a double "blip" tone to confirm the acceptance of the code.
Dec 23, 2008 | Avaya 5400 Series 5410 Phone
HI , I have the avaya phone, and i was wondering if it has call forwarding
IP Office?
*07*915551112222#
*01
*02
Dec 04, 2008 | Avaya 5400 Series 5410 Phone
Diverting incoming calls to another office
You have posted this question under the Panasonic system, but have mentioned the Avaya IP Office 5410. I can't help you with that.
However, for the "other user" that has the same problem, if you're trying to forward calls directed to your extension, you can forward them to any outside telephone number by using the Call Forward/Do Not Disturb (FWD/DND) button. The code numbers depend on your telephone system (the KX-T7633 can be used on multiple systems), and how your system was programmed by your installer, so I can't describe the exact procedure. Also, your extension may have been blocked from using this feature by your installer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jul 07, 2008 | Panasonic KX-T7633 Corded Phone
Avaya 5400 Series 5410 Phone Logo
132 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
