Question about Philips Magnavox MWR10D6 DVD Recorder
Channel select how do I select channel 3 or 4, so that the dvd shows up on tv screen......
  • Ival Jan 19, 2009
    I have cables channels, I can't seem to be able to record those three digits channels.
    Problem Solver:
  • 5 Answers
PUT YOUR TV ON 3 BUT MAKE SURE ON YOUR REMOTE FOR DVD PLAYER YOU PUSH THE DVD BUTTON .NOT THE TV
Posted on Aug 20, 2008
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Vhs won't show on screen
have you wired the dvd to the vcr or tv ? are you selecting the correct source[channel on the tv and dvd ]input must go to the dvd from the vcr first then on to the tv .you can go straight to the tv but some times this will not allow you to record signal.select the correct av source. hope this helped .farr64
Apr 30, 2009 | Televison & Video
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Up and down arrows on channel or menu selections not working.
All the functions of in putting and selections channel are done by one stage of a tv. take your tv to a w/shop, it wll require change of components,
get a diagram from
www.universal.remote.net/zenith.html
further help will be provided
Dec 06, 2008 | Zenith B25A02Z TV
Philips Magnavox MWR10D6 DVD Recorder Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
