Question about Nintendo DS Lite Console
When i plug in the charger no lights come on.i have tried with two chargers and its the same
    Problem Solver:
  • 8 Answers
It sounds like your battery is dead, or the port that the charger plugs into has died. I'd take it to GameStop or RadioShack and see if they can tell you which is the problem.
Posted on Mar 14, 2011
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Plugged in to charge battery, red light flashing, no green light on, charged all night still flat, what could be the problem.
Hi. Sounds like there is no connection between the charger and the batteries. The charger uses the voltage in the batteries to regulate the charge. If the charger is not connected then the charger will not operate at all.
The fault can be a broken wire in the charger plug, or faulty charger socket on the scooter. Can be caused by faulty battery connectors, or wiring from the charger socket to the batteries.
Try moving the charger plug in the socket while the charger is operating. These sockets sometimes wear and dont contact properly.
The best way is get someone with a multi-meter and try and trace the fault for you.
Good luck. Neil.
May 28, 2010 | Pride Mobility Products Hurricane PMV...
When I plug in the power cord to charge the battery, the light on the cord goes off. I tried several charges and they work. Can charged battery on another computer and place on the dead computer and it...
There's no fuse problem with that computer, try this first, Plug in the charger to an outlet don't plug it in the laptop, if the light on the charger turns on, then the charger is working try to plug it on the computer if the light on the charger goes out there's a problem with your motherboard. Contact the tech support for that so you can get that part replaced.
To double check try to use a known good charger if it works then you'll need another charger if not, Then contact your tech support for your dell make sure you still have a warrant.
Hope this helps!
Feb 15, 2010 | Dell Latitude D505 Notebook
Travel Pro Scooter charging problem. I plug in the charger there is no light indication on the charger when it is plugged into the scooter or when it is unplugged from the scooter. Batteries will not...
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
Jan 13, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
