Question about Frigidaire GLEQ2152ES Electric Dryer
Today i was trying to start the towels cycle and when i click start it beeps 3 times and then in the estimated time screen appears Dr and does not work. What can i do to fix it?
  • 1,998 Answers
Try pressing options and select for 10 seconds the door lock will lock the unit then do this again to unlock or the door isnt closeing properly or you have a loose wire to the door lock assembly this usually fixes the issue by locking and unlocking the door if not you may have to check the door lock assembly if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 14, 2011
Testimonial: "great answers and super fast!! thanks "
  • 3 more comments
  • johita0 Mar 14, 2011
    Thanks Rick but it did not work out. What else could be done??
  • Rick Ead
    Rick Ead Mar 14, 2011
    dr is a door error you could try replacing the door lock assembly as well. please do not rank our chat unit it is fully completed by ranking how you have it would cause my rating to drop and i always strive to achieve extremly helpful in all my chats one of our top experts has also answered this dr problem in this link as wellhttp://www.fixya.com/support/t5719808-fr... i will continue searching for the exact reason this does occur just please bear with me while i do and try to change how you ranked Thanks again Rick
  • Rick Ead
    ok i found it click this link http://appliancejunk.com/forums/index.ph... repair man has stated in his post that it is as I thought an open door circuit error although some have had to replace the board due to this defect in how it is made others have had to only replace the door lock assembly you would need to test which has malfunctioned and on that same link it also has how you can test both of these also look at brnt toast's post as well on the same link if you have any further questions message me back thanks Rick
    Rick,
    the weird thing is that it works in delicate but not in any other cycle.
    I have also tried the dryer tech data sheet test and everything worked fine. then lock and unlock the door and was also ok/
    I have no idea what to do and still have the dr message.
  • Rick Ead
    Rick Ead Mar 15, 2011
    according to that link it is due most of the time to a control board error these boards are known to have this problem after a period of time due to manufacturer error if you are unable to test the board and the door lock assembly you would call a technician for the repair. if you are well informed and adept at doing electrical tests look on that link to perform the tests personally you were saying the door lock is working and i would tend to look at the board as the problem source please remember to change the ratiing or I will not be able to further assist you in this matter I am already not able to comment and have to only reply Thanks Rick
    p.s by changing the rateing to even somewhat helpful it will keep it open until you are satisfied with the results Thanks Rick
Bwa91683x washer. When near the end of wash cycle. Beeps 3 times then wash light flashes, then beeps every 8 seconds. Washer still appears to carry on but doesn't start rinse cycle.
hmmm this could be a problem with the diagnostic computer having issues you may want to have the washer serviced it appears as if some sensors arent working inside the washer
Jan 08, 2017 | Washing Machines
Laptop was beeping with screen black on start up
Your battery is perhaps out of charge. verify it is holding charge.
The Dell Inspiron 15r n5110 battery appears to be notorious.
Check step 5 in the video below.
For the newer ones that have the battery on the bottom, look on the battery for a little white rectangle with 5 lights on it. There will be a button next to them. Push it. The lights will come on. The number of lights will give you an estimation on how much it has left.5-Full. 4-80%. 3-60%. 2-40%. 1-20%. None-0%. If it is a half, the lights will stay on and the last one will blink. 4+1=90%. 3+1=70%. 2+1=50%. 1+1 =30%.
Please go ahead and power off this system and when you power it on at the Dell logo, keep tapping the F2 key repeatedly for 3-4 times this will take you to the system set up. Please check the AC adapter type and Battery health under Advance tab.
Please follow the steps below within operating system (assuming windows) and let us know the status:
1.Click on start button and navigate to Control Panel>Hardware and Sound\Power Options
2.In the left pane of the window, Click on "Dell Battery Meter"
3.Click on "Battery Life " tab
4.Click on "Disable Battery Charging" and click OK
5.Reboot your laptop.
http://www.wikihow.com/Check-the-Charge-of-a-Dell-Laptop's-Battery
Mar 15, 2016 | Dell Inspiron 15r n5110 Laptop
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Dryer says locked
The Operating Instructions say this:
Control Lock
To avoid having someone accidentally start or stop
the washer, press OPTIONS and Select at the same
time and hold for about 10 seconds until the
(Control Lock) lights up. “LOC” will be displayed
alternately with the estimated cycle time. Turning
the Cycle Selector knob or pressing any button
will produce flashing indicator lights and/or beeping.
To unlock the controls, press and hold OPTIONS
and Select for about 10 seconds.
Oct 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Does not appear to be cycling water or pumping
You have created a suds lock condition with the wrong soap.
Take a shop vac if possible and vacuum out all water and suds. No shop vac, bail and wipe with a towel.
Then fill with COLD water from the faucet. Start the was cycle a few seconds. Then DRAIN. Repeat with cold water, wash then drain several times until the suds are clear.
You will know the suds are clearing each time you refill with COLD water and start the cycle. It will begin to sound like it is washing and pumping rather than humming.
May 05, 2009 | Dishwashers
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
448 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
