Question about Samsung Refrigerators
Refrigerater side temp started flashing.went to manual that said to disconect power 9 min. and plug back in. did so and temp read 59 degrees but would not come down. now what?
  • 1,998 Answers
First thing is the freezer side cold if the freezer side is cold but the refrigerator side is warm you would be having a defrost issue here is why this happens click this link http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm if you do not have any ice inside the back wall of the freezer you would also check that the fan is blowing the cold air into the freezer you can also check the fan in back of the rear panel inside the freezer as well if both the freezer and refrigerator sides are both warm this would most likely be a compressor issue and you would need to call a technician if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 14, 2011
  • Rick Ead
    Rick Ead Mar 23, 2011
    please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Refrigerator temp erratic
you will have to replace your thermostat of the fridge
you can find it near the light inside the unit
Sep 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
For no reason, my freezer went up to 56 degrees in a matter of 5-6 hours. I pulled the plug like the manual states because the temp was blinking. That solved the blinking. In 6 hours the temp dropped to 44...
You have either a sealed system problem or a control board problem. It's difficult to know which is which. You will need a qualified technician to determine what the problem is.
Good luck
Jun 17, 2011 | Samsung RS265LABP Side by Side...
I am getting the EAAF code. What does it mean?
The manual said to unplug the smoker and wait 10 secs and then plug it back in. I tried that and it did not solve the problem. However, I did leave it plugged in with that error code while I was searching the web for an answer. Over the next 5 min or so, the error code went away and my smoker started heating up as if it had no issues.
The solution may be to just let it sit for a few min and then it will begin on its own. The only variable I can think of is that I am smoking in cold conditions for the first time. It may be the case that since the smoker was outside in single digit temperatures, that may have triggered the error code. Who knows, in any case, I am back to smoking for Thanksgiving. Crisis averted.
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
86 gmc 2wd 305 slight cam. At initial start, engined fired and ran great for about 30 min or so at operating temp, then started stumbling and will no longer start. Spark was present at only 5kw though, not...
This works with the 5 prong module on an HEI ignition system with the coil that is mounted on the top of dist. The wires that come out of the back of the dist go to a spark controll module under the dash and they are junk. There is a conector on the wiring harness about 5" from the dist unplug that conector and run a jumper wire from the green wire to the black wire on the dist side and make sure you tape up all wires on dist side to keep them from grounding out. On the other side of the dist where your 12V goes in (batt conection) there are to wires piggybacked on top of each other disconect them from dis and plug only the pink 1 into dist at the batt conection. Where the wires on the back of dist run into firewall there should be a vacume line disconect and plug on engine compartment side. Thats how you do the bypass and the spark control module can be removed from under the dash if you want to but its not hurting anything to leave it there. BEFORE YOU DO ANYTHING MAKE SURE YOU DISCONECT THE BATTERY. When all this is done you mite have to advance your timing 8-15 degrees. I had to advance mine 12 degrees. let me no if you have any problems. kyle yeo
Oct 18, 2010 | 1986 GMC C1500
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Kenmore Side-by-side refrigerator
try unplugging it for 5 min and plug back in?
Jun 29, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
