Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Red light comes on w/code F2 can't find manual
  • 1,998 Answers
F2 is saying that it is a motor problem and to call a techncian here is the manual for the dd- 60 models in general as well http://www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/599732A_DD60_userguide_NZAUw.pdf if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 14, 2011
  • 77 Answers
F2 means that your rotor is bad and needs to be replaced. You can download the video in the link below to see how to replace the rotor and you can order the part in the link below if you wanted.
Appliance Repair Video
Appliance Parts
Posted on Mar 16, 2011
F2 SIGN COMES ON THE I F B MACHINE
F2 Is Usually A Trouble code, consult your manual or Go to manufacturers site for troubleshooting, usually on the help Link,
Good luck.
Apr 08, 2014 | IFB Washing Machines
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
I have a samsung 42 inch plasama ty model spp4231 when i try trunin it on the red light comes on it blinks 5 times them truns offWhat's your problem?
Hi the blinking light is a code. The service manual for this TV will have a description of the code. do a google search for the service manual and download it.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do you get rid of f2 error code,press off but comes back
This error code is telling you there is a problem somewhere. Every error code manual I could find from every brand states that the Error Code F2 means the over is too hot. Or, they harness or sensors could be bad. Other issues were mentioned. I would suggest having it looked at by a repair professional as it is most likely a safety hazard.
Feb 26, 2010 | Kenmore Kitchen Ranges
TV shut off...won't come back on ...red light indicator flashing ?
Tv shut off, won't come back on, red timer light flashing
Jan 24, 2010 | JVC AV-32120 32" TV
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
432 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
