Question about Ariston Technologies Dishwashers
Ariston LV 62 WH dishwasher serial number 303144138 When the machine is filling it makes a grumbling sound. Sometimes it then fills with water and completes the wash however many times it will start washing then after quite a while say more than 30 minutes the wash light will flash and the dishwasher will stop. The dishes are generally clean enough at this stage. However this week it has been grumbling then both the pre wash and wash buttons are flashing within minutes of dishwasher being turned on. Previously I had a tech come out and all he did was remove the hose from the inlet tap and then put back on again he said there had been an airlock. I do this myself now but at this point it is still not working. Looking forward to any suggestions as techs here arent the best.
Rotu
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
  • 62 Answers
SOURCE: Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Posted on Jan 03, 2008
  • 16 Answers
SOURCE: Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Posted on Feb 10, 2008
  • 1019 Answers
SOURCE: Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Posted on Feb 28, 2008
SOURCE: ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Posted on Feb 14, 2009
Food particals only on the upper shelf
Sounds like either the upper arm is clogged, or unable to move. Make sure nothing is in the way and that it can spin freely. Then, get lemishine machine washer (at grocery store) and run a cycle through - if it's hard water filling the holes, that'll solve it. Sounds too simple - but it actually worked for my exact machine.
Mar 09, 2014 | Ariston Technologies LI640S Dishwasher
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My dishwasher is running but not filling? Water is on & connected but can't work out why it won't fill. Any solutions? Thanks
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 13, 2011 | Ariston Technologies L63SNA Stainless...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Just bought a 4 year old maytag 300 quiet series and hooked it up all front buttons light up when you push what you want but will not fill with water. Goes to cycle where water should be spraying around...
Sounds like an internal timer malfunction.
Maytag Customer Service: 1 (800) 344-1274 U.S.
Try to find your model # and serial number if not out of warranty before called.
It sounds as if your machine needs to be inspected by a service repair agent in your area. Maytag can lead you to an authorized local repair man.
Oct 08, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Dishwaser Fills But Does Not Run
You may have a problem with the spray arm being blocked or the water valve may not be letting a sufficient amount of water through to get the spray arms activated. If the dishwasher is still in warranty schedule service before it runs out. GE customer service number is 800-626-2000 model and serial numbers and purchase dates are helpful. Ask specifically if any kits are available to fix these problems and if GE is willing to make any concession toward this repair. Good Luck.
Dec 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
Does not fill with water
fixed problem by throwing machine out into back yard and buying new one. seems to have worked up to now
Dec 03, 2008 | Ariston Technologies L63 Free-Standing...
Ariston dishwasher
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Mar 01, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
91 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
