Question about Kenmore Top Freezer Refrigerator
Refrig door only closes if i tape light switch down. Door has slipped and not sure how to fix it
  • 1,998 Answers
You would first check the door hinges to assure they are properly seated sometimes from the amount of weight on a door the hinges bend downward causing the door to swing open and not shut properly also examine the seal to assure there are no binds,rips or tears in the seal as well you can order new hinges for your unit by going to www.marcone.com under contact us there is a 1800 number and they deliver all over the world if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 14, 2011
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before:
Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)"
I hope this helps you out!
Apr 09, 2017 | Water Filters & Coolers
How do i get to the door ajar alarm in my 2002 kia sportage? Want to yank the alarm out.. Is it under the radio? Want to get an idea before i take the dash off again
there could be a bad or not totally depressed door switch/es when all doors are closed, assuming the alarm system module (not sure of the name, some manufacturers call it body control module-'BCM') is good. you may try the following:
1. if there is, tighten each lock nut (or mounting nut) of the door switches, to bring out each door switch so that they will be fully depressed when the doors are closed.
2. to find out which switch/es is not being fully depressed when door is closed: while (& all doors closed) door ajar alarm is on, open one door & manually depress the door switch (try to depress several times - might be sticking). if alarm turns off you found the switch, otherwise continue to the next door. but before proceeding to the next door, tape down that first door switch (you may have more than one?) once you found the switch that is not being fully depressed when door is closed, tape down that switch (to keep the alarm turned off). go back to each taped down switch. remove tape & close door, if the alarm turned off when the door was closed (switch is fully depressed=good), then go to next.
3. you can skip 2, just install spacer to doors. spacer can be a thin piece of plastic (or something weatherproof cardboard) to make the door switches to fully be depressed when doors are closed., not too thick that may prevent door from properly latching). tape them first, then use good adhesive if they work.
other possible causes are bad door switch, broken or detached wire, or bad BCM)
(note: the door switch is a push button which looks like a small protruding nail? & mounted at the door opening, which will be depressed by the door upon closing).
Oct 03, 2015 | Kia Cars & Trucks
My Amano top/bottom fridge freezer has no temperature in the fridge- my wife taped the light shut which left the control panel showing nothing but now the fridge works- my tech nician said I need to change...
A light switch failure can leave the light on even with the door closed, raising the temp. to over 40 degrees. Firstly, make sure doors are not sagging creating a switch activation with the door closed. If that checks good, replace the door switch.
Oct 07, 2017 | Amana ABB1927DE Bottom Freezer...
My Fridgidaire refrigerator door does not close tight every time without pushing on it.. There isn't any moisture around the door. The light switch button has put a dimple in the gasket. The button on the...
If it is placing a dimple in the gasket, this may be the culprit. Try taping the switch off with duct tape and closing the door to see if it seals properly.Also make sure you have all food items clear. this is another factor in doors not closing, especially freezers.
Jan 15, 2011 | Frigidaire Refrigerator Light Switch -...
Water dispenser doesnt work, ice dispenser works fine
Jul 19, 2009 | GE GSH25JSSS
Dometic RV refrig light will not go out
Open up the door to the freezer, you will see two black switches upper right just above where the door would be when closed. Flip the first switch, then push the switch on the light in the fridge compartment and the light should go out. Thinking that switch is there to help reduce moisture inside fridge, just got pushed by mistake and light remains on. Hope this helps.
Ron1247
Apr 08, 2009 | Dometic NDR 1062 Refrigerator
Light switch
correct, you can either take off the refrig door and place asmall shim under the hinge raising it an 1/8 inch or soor you can slightly pry down the light switch from the liner, and fill the small gap created with a small bead of silicone
Oct 23, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrig lights go on and off intermittently when opening and closing refrig door
check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Dec 26, 2007 | Sub-Zero 680 / F
Kenmore Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
