Question about Epson Office Equipment & Supplies
Epson R1900 - trash and ink light flashing together. Manual says Pictbridge has something plugged into it. I've never used it. Tried turning machine off and unplugging for 30 mins. didn't help. It started after I took out the yellow cartridge and put it back in. I had printed a Nozzle Check page and realized that no yellow pattern printed at all. I'm guessing the yellow nozzle is clogged but can't do anything further because of the flashing lights.
SOURCE: Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Posted on Oct 28, 2007
  • 27 Answers
SOURCE: Epson Nozzle check
hi sandysun,
try to deep cleaning at you nozzle from printer software at printer properties..it should help..
if still the same problem...u printhead got problem...try to take out you print head..put in the hot water..becarefull dont wet the chip near the print head
Posted on Jan 08, 2009
tigertail
  • 163 Answers
SOURCE: Black ink nozzle clogged
If you have tried 5 or 6 head cleans, left for about 10 hours and then tried 3 or 4 more without noticeable result then you probably need a head cleaning solution. Google for stockist near your area or try this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Hope this helps. Please take a moment to rate this solution, thanks.
Posted on Mar 25, 2009
  • 7 Answers
SOURCE: black ink nozzle clogged, cannot
if it has ink in it, then remove the black cartrige and take a damp cloth with water and wipe the print head,( once you wipe it a few times, you should see black ink on the cloth)
Posted on Jul 29, 2009
desertrat144
  • 22 Answers
SOURCE: Epson 4800 clogged
I've had similar fun(?) with my Epson. The best solution that I've found is getting by a drafting (or crafts) supply store and getting a jar of Rapiograph, Koohinor, or drafting pen cleaner. With any kind of luck all you'll need to do is 'flood' the print head a bit (let the solution pool around the cartridge intakes), and set a few minutes, then do the Nozzle check.
The next step if that doesn't get it, is to get an old 'empty' cartridge, add a teaspoon or so to the cartridge, then insert as usual- be quick, as the ink inside has been greatly diluted!
Cycle the printer off & on several times allowing 3-5 minutes between the first & second cycles. What happens during cycling is the printer 'charges' then 'empties' the internal ink tubes; the solution is drawn back and forth, washing out the tubes and jets.
Make sure that your cartridges are 20+% full when using them to print. Epson was one of the bad guys that showed empty ink supplies when they were still full.
Hope this helps.
Posted on Sep 13, 2009
Epson R1900 cartridge carrier goes lef and grinds until it stops with flashing lights
It;s general error or fatal error. Find the Adjusment Program for R1900, then Click Printer Information Check. You will find the latest fatal Error code. You can figure the actual error of your printer.
Jan 17, 2013 | Epson R1900 Printer
I have the Epson R1900 and I did a nozzle check twice and head cleaning twice. I am unable to check my supply levels. I am getting a message saying to only use genuine Epson Ink but that is what it
More than a little unusual that the printer is reporting non-OEM cartridges if those are the ones loaded unless your cartridge supplier has obtained their stock from another sales zone, in which case it may be that the printer is not recognising them as being valid.
Presumably, given the model you are getting the warning on your computer so you can disable this status monitor by doing the following:
- Open Printers & Faxes (or the equivalent for your operating system
- Locate your R1900 printer in the list
- Right click and select "Printing Preferences" (or "Properties" followed by "Printing Preferences")
- Click the "Maintenance" tab
- Click on the button marked "Speed & Progress"
- Tick the box marked "Disable status monitor 3.0" (The exact line may differ)
- Click Apply then OK
This should disable the annoying "Use genuine" warnings although it will also disable your ink monitoring capabilities via software.
I would still contact your supplier and/or Epson to complain about the problem and ask for replacement cartridges for the ones most recently changed as obviously this is something that should be covered under the cartridge warranty.
Hope that helps.
Dec 14, 2012 | Epson R1900 Printer
I have the R1900. Under all chip resetter so far I have not found one the mentions the R1900 or it's cartridges To87X. I know the cartridges has two chips one on top and a smaller one under it. What chip...
Have a look at this Adjustment Program Epson R1900 - Resetter Epson R1900
http://tricks-collections.com/adjustment-program-epson-r1900-resetter-epson-r1900/
I have not tried but I do not believe there is a hardware solution. Also check this site: http://www.efillink.com/AutoResetChip.html
They sell a set of refillable cartridges with an auto reset feature. They have a video which is also posted on YouTube which shows the refilling of their system.
Also found this which you may find of interest:
http://forums.dpreview.com/forums/read.asp?forum=1003&message=29300049
Would be interested to hear if the softwareresetter works out.
Dec 29, 2010 | Epson R1900 Printer
Power light is out and the two amber lights are flashing at same time.
Power off and paper and ink flashing alternately:
Parts inside the R1900 Series are at the end of their
service life or an unknown error has occurred. Contact
Epson for help
Power off and the paper and ink flashing fast:
The print head is obstructed by paper or other foreign
material. Turn off the printer, remove any obstructions,
and turn it back on. If the error persists, contact Epson
Good Luck!!!
Nov 02, 2010 | Epson R1900 Printer
When I turn printer on power light does not light and ink out and paper feed light flash alt slowely
alternating flashing lights on ink and paper could mean that your printer is locked The cause waste ink pads are full Option should be to take the printer to your nearest Service centre and have it diagnosed and new ink pads fitted cost between £50 to £60
Or you could remove the waste ink pads yourself and replace them or wash them out dry them using a hairdryer etc and replace them you will then need to have your prnter reset
What you will need is a service manual for your printer model, and a restet utility you can get the reset utility free of charge from the internet
May I suggest that once you have done this you consider getting an external waste ink jit and fit it
no more stripping the printer and messing with ink pads it only takes five minutes to fit and is very easy to empty
Mar 31, 2010 | Epson R1900 Printer
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
Ink button is steadily shining orange
did you peel the plastic off the back of the cartriges ?
Sep 16, 2009 | Epson R1900 Printer
Continuous Ink System Epson R1900 "Ink on" light illuminated
your R1900 chips has problem, you can try
www.inkrepublic.com
their chips works well
regards
Ruse
Oct 02, 2008 | Epson R1900 Printer
INK REFILL
get a new printer...this one is truly unhappy
Jul 29, 2008 | Epson Stylus C46 InkJet Printer
605 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
