Question about Sony KV-27S42 27" TV
Thermistor resistance value on Sony KV-27S42
Does anyone know what the resistance should be on the thermistor THP601 ( original part # 180358611 changed upto 180354111) in the KV-27S42 degausser circuit? I did order the part but they send me a 3 legged part, original was 2 legged. They said this was the replacement. It has 2 pieces of ceramic disc inside with a resistance on each of 9 ohms....total if I just connect the two pins of 18 ohms. Does that sound like the correct value? The old one was tested at less than 1 ohm....but it could be bad. Need to get a schematic to see what the value should be. Any idea where I can get that info? Thanks
  • BrianMcL Aug 01, 2008
    I need one number for an old TV I am trying to fix for my mother....I'm not in business and don't need the manual.
    It's a shame who everything boils down to money. Thanks for the help.....hope you sell alot of manuals.
  • 10,594 Answers
180358641 is correct replacement of THP601, Schematic (Service Manaul) is available on charge basis, have nice day!
Posted on Aug 01, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Aug 01, 2008
    I gave you desired number free of charge, manual is not free and you dont need it..why you are angry? I dont know either whos in business or not and I am in business. Rate my solution properly as its unfair.
    Shahid Electronics Aug 02, 2008
    Do you mind to change Incorrect rate?
    Shahid Electronics Sep 13, 2008
    hey,
    hopefully you fixed your tv now change solution rate too because its unjustified.
Farnell lf1 generator thermistor
All thermistors should be pretty much interchangeable. as they are a high resistance until a power surge hits them and then they are near zero resistance.
Oct 25, 2013 | Computers & Internet
E2 code no heat
The "E2" error code indicates a shorted thermistor. The thermistor is a component that the control board monitors in order to regulate the operating temperatures. The thermistor is a component that changes its resistance value according to temperature. If the control board does recognize a certain range of resistance of the thermistor, the control board will stop the dryer and display "E2".
Feb 14, 2013 | Kenmore Dryers
Kenmore Elite stops early and flashes e1. How do we corect this Thanks Todd
The electronic control detected the thermistor is open. The wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting and replacement procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Feb 13, 2011 | Kenmore Dryers
My whirlpool duet dryer is coming up with a code E2 and turning off. Do you know why?
The fault code E2 means the electronic control detected the thermistor is shorted. It's either the wire harness connecting the thermistor and electronic control is shorted or the thermistor is indeed shorted or its resistance is too low. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Replace the thermistor if the measured resistance is not in the table.
Check the wire harness for short circuit if the thermistor resistance is good and make sure the connectors are inserted correctly to the appropriate terminals. Replace the harness if shorted. The problem lies in the electronic control board if no issue is found in the harness and the connections.
The thermistor is located on the blower housing and can be accessed through the toe panel. Shut off the gas supply if the dryer is gas type and disconnect electrical power. Remove the two hex-head screws from the bottom flange of the toe panel then pull the panel down and off the cabinet.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct.
Remove at least one of the wires from the terminals of the thermistor when measuring its resistance. Remove the two-hex-head screws securing it to the blower housing when replacing it and install the new one. Reassemble in reverse order of the disassembly steps.
Feb 09, 2011 | Whirlpool Dryers
I get an E1 code on a whirlpool duet dryer. What could the problem be.
The problem is the control thermistor being detected open by the electronic control. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Feb 04, 2011 | Whirlpool GEW9250 Electric Dryer
E1 error
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Dec 31, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
A code E1 flashes the dryer shuts off and the clothes are still wet
Oct 25, 2010 | Kenmore HE5
Anyone know what code t0 means? Dryer will start but never finish drying clothes regardless what cycle you're on.
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Replace themistor if out of range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Samsung DV337 Electric Dryer
How do i know wether the thermistor is shorted / open, defective?
Hello clydex,
Yes you can use an ohmmeter, however you will need a hot air gun to. Let me explain: There are two types of Thermistors +Temperature coefficient and - Temperature coefficient.
The +temperature thermistor reacts this way: as the temperature goes up so does the resistance of the device this is used when dealing with degaussing coils as the current passes through the coil it heats up the thermistor until the thermistor cuts off the current needed to run the coil.
The -temperature thermistor reacts this way: as the temperature goes up the resistance decreases, this can be seen when dealing with circuits that are designed to short out when excessive current is present. The excessive current causes the thermistor to heat up and the the resistance drops causing the device to short out.
Here is how to do it.: connect the device to the ohmmeter and use the heat gun to heat the component up the value of resistance should rise or decrease.
I hope this helps,
Thank you,
Shuttle83
Dec 23, 2007 | Televison & Video
Hello clydex, Yes you can use an ohmmeter, however you will need a hot air gun to. Let me explain: There are two types of Thermistors +Temperature coefficient and - Temperature coefficient. The +temperature thermistor reacts this way: as the temperature goes up so does the resistance of the device this is used when dealing with degaussing coils as the current passes through the coil it heats up the thermistor until the thermistor cuts off the current needed to run the coil. The -temperature thermistor reacts this way: as the temperature goes up the resistance decreases, this can be seen when dealing with circuits that are designed to short out when excessive current is present. The excessive current causes the thermistor to heat up and the the resistance drops causing the device to short out. Here is how to do it.: connect the device to the ohmmeter and use the heat gun to heat the component up the value of resistance should rise or decrease.
I hope this helps,
Thank you, Shuttle83
Dec 23, 2007 | RCA F38310 38" TV
Sony KV-27S42 27" TV Logo
261 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
