Question about JUMP START SYSTEM
My clarke jump start 400 has been left to go below charging threshold, can it be resurrected ?
  • 9,845 Answers
Connect it to the car's battery, turn the start switch on after you start the car. Let it run for 10 or so minutes then take it off and top off the charge with the charger
Posted on Jan 23, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a D5805 STARTER-UP 400 Jump Starter and need instructions for it. where can I get them.
you can buy one at any good car sale shop and make sure you
read all the instructions before useing it as jump starting is always fit red [POS] cable to both cars or batterys first and then fit the black cable lead last,when finished remove the Earth lead [black]First with car doing the charging turned off.
When charging car to car let engine run for approx 4 minutes at 800 rpm then let it idle for 2 minutes before starting the second car
Nov 16, 2014 | Cars & Trucks
On vector jump starter 400, what will the display state when fully charged?
THERE SHOULD BE A BUTTON ON IT TO CHECK CHARGE STATUS.
Jul 24, 2012 | JUMP START SYSTEM
A Sony Clie PEG-N610C has been in storage for years(it appears unused). Neither the AC charger or the cradle charger will make the charge indicater light respond. It is completely dead in all respects. Can...
Since the battery is within the unit it can leak or go BELOW the threshold level of the cell wherein the charger will not work to charge the unit. However if you can confirm the battery voltage to be below, use a multimeter to check, then before replacing use a JUMP START with an external limiter DC bench supply , you can use a series resisitor of about 47 ohms with a 6-9 VDC.
If the battery takes up voltage the see if the charger will respond and the set will power.
Sep 30, 2011 | Sony CLIE PEG-N610C Handheld
I have lost manual for clarke 4000 jump start having never used it since purchacing,how do i charge it up,is it with the start switch turned on or off.i would be grateful for any help or can i download a...
The manual for the Clarke 4000 is available here: http://www.clarkeservice.co.uk/manuals/jumpstart/jumpstart4000.pdf .
You can charge the unit either with the 230V DC adapter plugged into your wall outlet or by using the 12V adapter plugged into the cigarette lighter (assuming the battery is good) of your vehicle.
If you are using the wall outlet, plug the end of the power cord into the charger then plug it into the wall outlet. Then turn on the charger. Disconnect when the red charging LED goes out. (If you press the TEST button, you can find out the state of the battery. After a number of charge/discharge cycles (even when unused), the battery will need to be replaced every few years.)
I hope this helps.
Sep 21, 2011 | Garden
My u600 samsung phone has been lying around for months with out use now that iv tried to charge it up it wont go
If the battery was not charged for a longg time then it will develop reverse polarity there by reducing the life of the battery going below the threshold level. It will then not allow the battery to build up charge and so this must be replaced. In some cases a higer voltage JUMP START might improve the battery base voltage but is not very efffective except to check and confirm.
Aug 03, 2011 | Samsung SGH-U600 Cellular Phone
Hey. I have nikon coolpix. when clicking the pics battery was low and got shut down automatically.. tried reaching with the adopter still not showing green light. tried with the laptop still notings...
It is quite possible that if the battery has gone down below the threshold limit or has developed back emf then it is difficult to charge it the normal way. You can use a trigger/jump start charging so as to bring it to the set level from where it will take up charging.
But in the first place use a multimeter to check the voltage on the battery, once confirmed you can try the charge externally and if this wont help change the battery.
If battery is showing good voltage then you must check the voltage on the adapter.
Mar 11, 2011 | Nikon Coolpix 3200 Digital Camera
I gave a jump to my 1993 400 sel now the abs and asr dash lights will not go out and the speed ometer does not work
Check fuses, you are not supposed to "jump" MB thats why they have forever roadside assistance. You charge battery while disconnected and reconnect to start.
Jan 29, 2010 | 1993 Mercedes-Benz Mercedes Benz 400 Class
JUMP START SYSTEM Logo
85 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
