Everry once in a while. More often now. The screen turns a transparent green color then returns to normal.
  • 68 Answers
Bad hdmi cable ?
Posted on Mar 14, 2011
  • zacheryl Mar 14, 2011
    No hdmi.
  • williamracin Mar 14, 2011
    try with other cable to be sure at first that you don't have bad cable...
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen Turns Pink-Mitsubishi 57'' Wd-Y57
since dlps use a color wheel to make the color the color wheel may be going out. get it serviced
Nov 15, 2008 | Mitsubishi WD-Y57 57" Projection HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
