Question about Ovation MM68-CCB Acoustic Electric Mandolin
Is the red light indicator ment to stay on all the time when playing, or is this a warning light to let me know that the battery is low .Thanks and kind regards Neil
  • Ovation Master
  • 5,603 Answers
Simple test to try: Put in a brand new battery... If light goes out, then it is a low battery warning.
HOWEVER, it is likely a warning that battery is on so you don't forget to turn it off when done. Tried to find manual for it and could not. Your manual should tell about it.
Posted on Mar 14, 2011
  • prostreet 55
    prostreet 55 Mar 15, 2011
    mine stays on to let me know it has power
  • Fred Yearian Mar 15, 2011
    That is perfectly reasonable. It also shows the battery is being drained so you remember to turn it off when done.
How to set up and check the digitech qm1548 multimeter and tell me how to check a 12volt truck battery
put the black wire in the black hole , the red wire in the red hole
turn the knob( press the buttons ) to volts ad/dc adjust range to high voltage ( put the decimal point 3 places to the right on the screen
connect the black wire to the negative pole of the battery
put the red wire to the positive pole of the battery and read the dial /screen
the reading on a good battery will be 12 volts to 13.5 volts
now have some one start the engine
check the voltage while cranking-- should be no less than 10.5 volts ( anything less indicates a faulty battery)
once the engine is running increase rpms to around 2500 rpms
battery voltage should now read 14.5-14.8 volts
if it stays at 12 volts , the alternator / regulator is not working
if the running engine voltage is at 11 volts , the battery is supplying power to the electronics
Of course if you do not know how to read a multimeter or know how to follow the user instructions for the meter, what I have detailed here will not mean much , so take the vehicle to an accredited auto electrician and have a proper diagnosis done
Aug 22, 2016 | The Music
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
Limiter light stays on with no sound. powers up fine but again the red limiter light stays on and no sound.
The power amp is likely blown. The limiter also indicates when the amp is out of DC balance.
May 14, 2011 | QSC HPR 153
On my fender blues deluxe, there is a red light which is usually off. I get intermittent loss of sound, and when this happens, the red light comes on. Any ideas what's wrong? Many thanks Brian
Hi.
If the red light is coming from a tube and you notice a loss of sound when it lights up, try reseating the tubes. You have to make sure that the amplifier is cool and is not plugged in to any power source when you do this and you have to be very very careful with the glass tube as well.
If the red light comes from an LED, it may be an indication of a bad wiring. Check if all wires are in good condition and are soldered correctly.
I hope this helps. Thanks. :-)
Apr 28, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My tuner shows a green flashing light, the battery is new, even checked it with another one. No matter what i do it just shows a green flashing light. picking the strings for sounds makes no difference at...
Often, the flashing green light indicates that the tuner is NOT receiving a signal and is a warning that the tuner is turned on.
First thing is to check if you have normal output from the guitar from the pickup. If the output is normal, there MAY be a failure in the tuner.
ALSO, just because a battery is new doesn't mean the battery isn't depleted... either try another from a different batch or use a voltmeter to check it. I have seen people chasing their tails due to a brand new bad battery.
When you select the tuner does the audio OUT of the guitar cut off as it is supposed to?
Sep 03, 2010 | Washburn D10sbc Acoustic Guitar
I have a phillips universal remote. I need the
Hello. The codes you seek are these: SYMPHONIC..... 520 904 906
AND here are the instructions:
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Dec 06, 2009 | Music
Power indicator light is red and the system does
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
Oct 17, 2009 | Fender Passport Deluxe 500watt Sound...
Ovation MM68-CCB Acoustic Electric Mandolin Logo
250 people viewed this question
Top Ovation Music Experts
Computer Links
ray gallant
rhodesworks
Are you an Ovation Music Expert? Answer questions, earn points and help others
